lightend flywheel in a escos
Old 04-09-2011, 11:50 AM
ginner
ginner's Avatar
Default lightend flywheel in a escos
as above i need to replace my clutch soon so is it worth lightening and balancing my flywheel my spec is t35/55 standard engine ,seimens 55,approx 380bhp
thanks
Old 04-09-2011, 12:16 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
might as well, how much you get taken off is up to you really, too much and idle goes lumpy.
more than anything get it balanced.
Old 04-09-2011, 12:33 PM
DAN400
DAN400's Avatar
just change it too a standard 2wd flywheel
Old 04-09-2011, 02:12 PM
ginner
ginner's Avatar
what benefits will i see by changing 2 a 2wd one,
am i right in thinking that if it get lightend the car will rev quicker and effectivly come on boost sooner but i will loose some torque
Old 04-09-2011, 02:16 PM
RS500/364
RS500/364's Avatar
worth it if doing the crank but say no if not
Old 04-09-2011, 04:24 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
you will lose no torque, that's a myth as it doesn't even follow any physics to make that happen.
what it will do is make the car rev easier, won't make boost any sooner, but reduces load on engine a bit.
however it will slow the engine sooner on overrun and you'll feel the effect of a hill sooner as the car will slow easier if you don't put your foot down sooner to compensate.
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Mark_
14
16-01-2016 05:27 PM
Jman-pat
Ford Focus Diesel
08-11-2015 01:29 PM
gcfcos
59
06-10-2015 05:04 PM
Mickeystewart
09-09-2015 04:04 PM
Quick Reply: lightend flywheel in a escos
