'diffs'
Old Jul 28, 2011 | 08:04 PM
Bigman1's Avatar
Bigman1
Default 'diffs'
Hi people, I have a 3dr cosworth which am building and converting it to a 4x4. what I'd like to know is please if the standard 4x4 diffs are capable of 500bhp, if not, what diffs and ratios shall i need in order to manage that sort of power and be reliable many thanks!!
Old Jul 28, 2011 | 08:12 PM
big_wig_074's Avatar
big_wig_074
ill answer your first question
no
second answer is here
http://www.randbmotorsport.co.uk/sho...ID=3&offset=20
rear diff Ł1022 plus delivery
front diff Ł581 (plus Ł218 installation)including delivery
front diff casing Ł752 including delivery
so not exactly cheap
Old Jul 29, 2011 | 12:52 AM
Bigman1's Avatar
Bigman1
no
Hi mate, thanks for the link, is there no other cheaper option? I was reading a thread where it stated there are some cars out there running fairely decent power with low ratio diffs but I cant figure out what ones they are using
Old Jul 29, 2011 | 09:36 AM
R4N SS's Avatar
R4N SS
keep it rwd
ive got a 7" 4x4 cossie diff in my saff and going for close to 500bhp when the yb goes in and i just know that the diff will break in the first couple of launches
Gonna get a 7.5" in there once it goes
Old Jul 29, 2011 | 09:39 AM
grcossie's Avatar
grcossie
Use your 7,5" oe diff then the 7" 4x4.
I will using a Scorpio Cosworth 7,5" diff on my escos, it`s stronger than the 7" and it`s bolt on whit 4x4 drive shafts
Old Jul 29, 2011 | 09:46 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
its torque that kills them and standard diffs fall apart with about 350lb ft then the crown wheel and pinions brake as well with more torque if you really abuse them and why are you 4x4,ing it just one big can of worms as the gearbox,s are week too its just big money getting it all to cope!
Old Jul 29, 2011 | 09:52 AM
big_wig_074
not really,but thats just the beginning of your problems,the gearbox will also break at that level,no ifs or buts,it WILL break,and the price for a fixit,which is nowhere near the most expensive gearbox. Ł3050 (plus Ł275 for an uprated 1st gear)!!!!
http://www.randbmotorsport.co.uk/sho...ID=3&offset=10
Old Jul 29, 2011 | 09:56 AM
big_wig_074
and just for a balanced approach,in case you think he is more expensive than others,here is the link to reylands transmission stuff,its not cheap going 4x4!
http://www.reyland.co.uk/Parts.asp?ID=4
Old Jul 29, 2011 | 10:07 AM
R4N SS's Avatar
R4N SS
you will need the driveshafts if using a 7.5" diff as they are different from 4x4s
Old Jul 31, 2011 | 11:46 PM
Bigman1's Avatar
Bigman1
wow, thats a lot to take in!!
Old Aug 1, 2011 | 08:35 AM
NEIL A's Avatar
NEIL A
At around 500 bhp you may get away running a standard 7.5" rear diff, but you will need to uprate the front diff to a titan,gripper,quaife or similar front. Ideally you would want a thickwall front housing but if it isnt running huge torque you could try a standard case with a brace plate fitted.
Old Aug 1, 2011 | 06:59 PM
marco polo's Avatar
marco polo
ran
your right but most granada's have 7.5" diff with 100mm drive shafts like the 4wd cossie
Old Aug 1, 2011 | 07:25 PM
Bigman1's Avatar
Bigman1
cheers for info!!
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
