2.0L injection pinto starts but wont hardly rev
Old 06-07-2011 | 11:59 AM
1348davidh's Avatar
1348davidh
HellraiserHippy
Default 2.0L injection pinto starts but wont hardly rev
Got mk 2 escort with 2.0L injection pinto engine, car will start but throttle needs playing with to keep it running, I can build the revs up and floor it but it will only go to about 3000rpm then it dies back down again. Any ideas? Have thought about air flow meter, throttle body (which from looking appears to be working) or could it be ECU? Cheers
Old 06-07-2011 | 12:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Idle speed control valve is first on the list
then it's the air flow meter, push the flap and see if you can feel it sticking anywhere, if you can it's fubar and you need anoher one
Old 06-07-2011 | 12:15 PM
1348davidh's Avatar
1348davidh
HellraiserHippy
Air flow meter feels fine but where do i find idle speed control valve? I not to clued up on injection systems! Oh thanks for your time. This all new to me.
Old 06-07-2011 | 12:27 PM
dojj's Avatar
dojj
It's on the side of the inlet manifold, at the top above the rocker cover from memory, looks like a metal tube with wires comic out of it about 6 inches long and it's got a step in it and 2 little bolts holding it in place
Old 06-07-2011 | 12:46 PM
S1-Tiz's Avatar
S1-Tiz
done anything with the cambelt recently? Or ignition timing?
Old 06-07-2011 | 01:58 PM
1348davidh's Avatar
1348davidh
HellraiserHippy
Cool! yes iv seen it and wonderd wot it"s job was! lol.Is ther any way of cheking it or just replace it? No havent touched timing atall.Although when it first happened,i initially thought it had sliped on the timing belt or something like that but all looked tickety boo and she still starts kinda ok so hence im looking in to throttle system.
Old 06-07-2011 | 02:00 PM
S1-Tiz's Avatar
S1-Tiz
has it just started doing it all of a sudden? Fuel filter cause cause it if its really clogged. Or even fuel pump!
Old 06-07-2011 | 03:29 PM
1348davidh's Avatar
1348davidh
HellraiserHippy
Just went all of a sudden! definatly not fuel line or pump problems.
Old 08-07-2011 | 01:45 AM
bortaf's Avatar
bortaf
Check the 1 or 2 breathers under the inlet they may have come off and are sucking in air ?
Have you checked the fuel presure reg ?
Old 08-07-2011 | 06:30 PM
Icurus's Avatar
Icurus
Does sound a bit like a fuel pressure problem.
big_Rad
15-09-2017 10:36 AM
Johnsie
Ford Focus ST
08-09-2015 03:39 PM
Bailes1992
03-09-2015 03:17 PM
wheelwizardrefurbs
06-08-2015 08:40 PM
CabrioTurbo
01-08-2015 12:04 PM
