replacing sump drain plug
Old Jun 24, 2011 | 10:40 AM
lukeytheduke's Avatar
lukeytheduke
Default replacing sump drain plug
hi im doing an oil change and am going to replace the sump plug. Halfords sell them for 2quid and they say it fits. But they cant give me any details to check. Do u know if it will fit??
Old Jun 24, 2011 | 10:41 AM
chaffe's Avatar
chaffe
Turbocharging Technician
If it doesnt then put the old one back in
Old Jun 24, 2011 | 10:42 AM
bythomson's Avatar
bythomson
just go to ford an buy a real one canny be that dear and it means you have piece of mind
Old Jun 24, 2011 | 10:50 AM
lukeytheduke
Haha genious idea mate i'l keep that in mind
Old Jun 24, 2011 | 10:51 AM
lukeytheduke
there isn't a local ford dealer near me. If anyone knows the size of thread or head i could measure it before i buy it
Old Jun 24, 2011 | 11:14 AM
chaffe's Avatar
chaffe
The problem is, is what the fuck is it for?
Old Jun 24, 2011 | 11:23 AM
lukeytheduke
draining the oil out mate from the sump
Old Jun 24, 2011 | 11:34 AM
chaffe's Avatar
chaffe
any particular car???
Old Jun 24, 2011 | 11:59 AM
BigErn's Avatar
BigErn
whats wrong with the old plug??
Old Jun 24, 2011 | 12:07 PM
haz87's Avatar
haz87
m14 x 1.5 is the usual ford fitment
Old Jun 24, 2011 | 12:40 PM
chaffe's Avatar
chaffe
Exactly, Ive never changed one yet
Thats true but no one has mentioned a make and model?
Old Jun 24, 2011 | 01:00 PM
haz87's Avatar
haz87
Im just taking a wild guess being a ford forum
Old Jun 24, 2011 | 01:08 PM
chaffe's Avatar
chaffe
So the volvo engine in the st/rs, the yamaha engine in the small zetecs, the peugeot engines in the diesels and the mazda v6's all have the same sump plug threads?
Old Jun 24, 2011 | 01:14 PM
lukeytheduke
rs cosworth mate. And i have a feeling im going to have to use a lot of force to get it of as i cant remember the last time the oil was changed!lol
Old Jun 24, 2011 | 01:15 PM
chaffe's Avatar
chaffe
good luck
Old Jun 24, 2011 | 01:16 PM
haz87's Avatar
haz87
The volve engine is the same actually
Dunno about the rest, but at least ive put up something useful rather than talking about how you've never needed to change a sump plug! I imagine he's either fooked the threads or rounded the head. Not that hard to work out is it.
Old Jun 24, 2011 | 01:17 PM
chaffe's Avatar
chaffe
it is when you are not given the correct information in the first place
Old Jun 24, 2011 | 01:26 PM
Just be aware it may have been bodged in there in the past, and have knackered threads!!
No need at all for all this sump plug replacing, the cossie(2wd anyway) is only torqued up to 21-28NM.
I always put sealant on the threads, not a single drop of the oil stuff will leak from here then.
Old Jun 24, 2011 | 01:46 PM
lukeytheduke
just an exterior sealent or one specially made for oil?
Old Jun 24, 2011 | 01:47 PM
lukeytheduke
Do u know if M14 1.5 is correct? I presume its 1.5 inches?
Old Jun 24, 2011 | 05:22 PM
lukeytheduke
whats the thread size and length for a 2wd 89 saph cossie?
Old Jun 24, 2011 | 08:35 PM
Mark_'s Avatar
Mark_
what type of sealant do you use on sump plugs tab
Old Jun 24, 2011 | 08:49 PM
I'm pretty sure the 2wd cossie is 14 x 1.5, about 3/4" long.
I just use either loctite 5900 or 5910, or steal my dads hylomar, as it's free!!
I have always used sealant on the threads, started doing this when I needed a new plastic washer on a sump plug, on a renault I think it was about 25 years ago.
I've never seen a single drop leak from any sump plug this way, even those later where I didn't even bother to fit a sealing washer that didn't work in the first place.
The only issue I have found is cars with pressed steel sumps, the sump rots, as it is no longer covered in oil, but this takes years and years, if pressed tin sumps I would put underseal etc on them to stop the rust.
There isn't really any chance of hylomar getting into the engine, as it has to get to the end of the threads to start with, and even if it did get into the pump, it is so soft it would cause no harm, and would soon be mashed down.
I don't use loads of it, I just put a 5mm dab on my finger and spread it around the whole bolt, all the way from top to bottom, firmly so it is just in the threads rather than sitting on them, when the plug is tightened up, it will spread out over the sump plug head just wipe off, this shows it is well sealed.
Old Jun 24, 2011 | 08:56 PM
Mark_'s Avatar
Mark_
learn something every day, i wouldnt have thought locktight was oil resistant.
Old Jun 24, 2011 | 09:00 PM
lukeytheduke
does the length matter as 3/4 inch is 1.8cm and 1.5cm is 5/8ths. I guess the crucial size is the m14?
Old Jun 25, 2011 | 11:35 AM
S1's Avatar
S1
The stuff Tabetha is talking about is called a flange sealant so not a threadlock as such. I certainly wouldn't start putting threadlock onto a sumpplug, that's asking for trouble.
Old Jun 25, 2011 | 01:08 PM
cossie891's Avatar
cossie891
Why cant you just buy 1 of stus magnetic sump nuts eh
Old Jun 25, 2011 | 01:17 PM
lukeytheduke
Not for 20quid mate i could 3miles worth of fuel for that haha
Old Jun 25, 2011 | 07:52 PM
Loctite make lots of sealants as well as thread lock and stud lock, 5910 is well expensive though, around £18 for a small tube like a hylomar size.
Old Jun 25, 2011 | 07:54 PM
It is indeed, the 5910 is used on production lines due to it's fast curing time - 5 minutes at most, awsome stuff though.
Old Jun 27, 2011 | 05:45 AM
chaffe's Avatar
chaffe
Took me three mins to change the oil and filter on my car yesterday, without using any sealant or even thinking about changing the sump plug or washer. It doesnt leak, and it wasnt a problem.
Old Jun 27, 2011 | 07:57 PM
3 minutes, you should start a comedy act next, think you'd be good.
Old Jun 28, 2011 | 06:18 AM
chaffe's Avatar
chaffe
It wasnt more, an Impreza has to be the easiest thing in the world to do an oil and filter on.
Old Jun 29, 2011 | 08:38 AM
gingerxr2's Avatar
gingerxr2
tbh i change my sump nut n washer every oil change on my xr2,only £3
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
little bram
Sep 21, 2015 02:50 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
