clutch issues, help needed asap
Old 29-04-2011, 07:47 PM
boost mad
boost mad's Avatar
Default clutch issues, help needed asap
ok, the story is the gearbox was changed and whilst out i swapped the thrust bearing. once changed i also changed to a hydraulic clutch. now the biting point is realy high and it doesnt disengauge fully. anyway, the box had to come back off again as it was fucked, so whilst out i had the clutch repadded and fly skimmed. so, box fixed fly and clutch back on, and its still the same. even changing back to a cable its the same.
why is it doing this, my mot is tomorrow
Old 29-04-2011, 07:52 PM
paul16v
Monte 087
paul16v's Avatar
Is it on a 4x4 cossie? if so have you fitted a 2.0L 4x4 box insted of a cosworth one?
Old 29-04-2011, 07:54 PM
boost mad
boost mad's Avatar
it is a 4x4 yes. ive fitted what i thoight to be a cossie one, it was yums old bara box
Old 29-04-2011, 07:57 PM
paul16v
Monte 087
paul16v's Avatar
All I was thinking is the clutch arm on the 2.0L 4x4 box is slightly different from the cossie one and if you fit one by mistake when putting one of these boxes into a cossie it gives you this exact problem.
Old 29-04-2011, 08:02 PM
boost mad
boost mad's Avatar
i did buy a second hand clutch arm!!!!! was sold as a cosworth one though. bollocks.
a friend of mine has the same issue but on a 2wd tho, except he hasnt had a box change, he has just changed his thrust bearing.
i realy dont wanna take that pissing box off again
Old 29-04-2011, 08:07 PM
paul16v
Monte 087
paul16v's Avatar
Im 99% sure thats your problem then bud, we had a fucking nightmare like this a few years back, really pulling our hair out with it had the box in and out at least 4 times untill we realised what the problem was
Old 29-04-2011, 09:27 PM
boost mad
boost mad's Avatar
Anyone else ?
Not saying your wrong Paul, just want other opinions before i take the box off, again lol.
Is the way it is now going to pass an MOT ?
Old 29-04-2011, 09:53 PM
fraser9764
fraser9764's Avatar
so long as it drives into the garage the MOT should be fine i think.
Old 29-04-2011, 09:56 PM
saph4be
saph4be's Avatar
gearbox don't come into mot
Old 30-04-2011, 04:32 PM
boost mad
boost mad's Avatar
Ok, so it seems to disengauge now, but the biting point is still silly high, like, higher than the brake pedal and it slips when it comes on boost
Old 30-04-2011, 04:39 PM
cossie daz
cossie daz's Avatar
your luck doesnt get any better does it
when you said mot i thought it was all ok
yums bloody gearbox has been problems no end
hope you sort it
Old 06-05-2011, 09:42 PM
boost mad
boost mad's Avatar
update.
had the box off this evening, got another clutch fork which i have been assured is a 4x4 cosworth one and they are identical down to the part number.
dont know what to do know, got to wait until tuesday to fit my other box as im selling my bara one so any ideas before then would be greatfully recieved
Old 06-05-2011, 10:18 PM
jameswrx
jameswrx's Avatar
Was it ok before you started this work?
If so then all you changed was release bearing and to hydraulic actuation in the first instance? Then you swapped back to cable and it was still high, so maybe points towards the release bearing, is it fitted correctly to the arm? Can't remember how they go on cossies as haven't played with one for over 10 years! But don't they clip into the arm?
Although saying that if it's protruding it'd prob have the opposite effect.
Maybe your pressure plate is fooked. Or flywheel been skimmed too much
Old 06-05-2011, 10:31 PM
boost mad
boost mad's Avatar
i basicly changed the box, clutch arm and release bearing and hyd clutch, then the box went on, clutch was high, so went back to cable and was the same . The box came off as it popped out of second so whilst off i had the lutch and flywheel done. box back on and its still the same.
an above reply said it may be the clutch arm so i sourced another but looking with the box off tonight the arms are the same, so it leaves the msd thrust bearing as thats all i can think of now
jessie_rs
11
03-06-2019 04:57 PM
Chas
21-09-2015 08:57 PM
col93saphcos
07-08-2015 03:21 PM
Caddyshack
15
04-08-2015 08:50 AM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
Quick Reply: clutch issues, help needed asap
