Vw tech help
Old Mar 1, 2011 | 06:19 PM
bigjohn0's Avatar
bigjohn0
Angry Vw tech help
I am having trouble with my passat 1.8 20v 1999
I have asked on a few vw forums but they are a bunch of wankers and dont help no one so i thought i might try here as i know you lot are very helpful
After a few miles driving it starts to run like shit and the cat stinks so i plugged my comp in it and get the code C1500. I have been all over the net but not had any luck finding the code. I have tried a new air flow meter and that didnt fix it so i have a feeling its the lamba sensor causing me the trouble.
Any help on this would be great guys as i am about ready to burn the fecker out
Old Mar 1, 2011 | 06:31 PM
vaughant's Avatar
vaughant
Can't help with an exact passat problem but my escort 1.4 did this and the cat was blocked,I manually "de catted" it and she was spot on,might be worth a look?mine sounded like it was hissing,no power and in the end it acually failed,just died on a hill.
I left it 5 mins and it started and it wouldn't hit 60,after the decat it saw 115!!!
Did tap a bit after that!!
Old Mar 1, 2011 | 07:24 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
happens to mate .hes car goes into limp mode! slow] so got it resetted was fine.. then happended again it was the cat! clean the egr valve aswell or whatevrer they are called
Old Mar 1, 2011 | 07:25 PM
bigjohn0's Avatar
bigjohn0
Ty for the reply vaughant but its not the cat as i have loads of pressure at the back box as i thought the same but clear the code and its mint again for a few miles. I think its the lamba sensor playing up as when i go into live data its not switching much at all.
Just dont want to buy one to find the code is for something different and chucked more money away. The thing that gets me is why the hell dont vw use the same codes for stuff as other car makers
Old Mar 1, 2011 | 07:32 PM
bigjohn0's Avatar
bigjohn0
Ty mo for the reply and i will deffo try splitting the exhaust at the cat and see if its falling to bits. Anything is worth a try at the min as i am getting a bit sick of stopping all the time and clearing the code just to drive the bloody thing
Old Mar 1, 2011 | 07:42 PM
mac456's Avatar
mac456
you should get a proper vagcom lead on it to get a proper code
Old Mar 1, 2011 | 07:50 PM
xrt-mart's Avatar
xrt-mart
You sure its not a p code not c?
P1500 code for VW would be fuel pump relay malfunction in circuit...
Old Mar 1, 2011 | 08:13 PM
bigjohn0's Avatar
bigjohn0
I will kick its head in tomoro on the way to work then use the garage code reader to see what that comes up with.
Thanks for all the reply's guys
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
