Cossie Rear Suspension.. Normal??
#84
Caraholic
I didn't, but that is the only reason I could think as to why the ride height was so low.....
FYI, the Ahmed springs are NOT standard height (and I would never have told you this
), they lower a 3dr by 10mm
I think you went for the 10" fast road rear springs? These are the same as for any Sierra Cosworth (it is only the fronts which are unique to the 3dr), which should have given you a similar ride height to the ones in this thread, so something defo looks amiss:
https://passionford.com/forum/pictur...saffs-sit.html
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
#85
I couldnt remember if you told me or few people on the board did mike.
It sits like that on level ground.
The pics are taken when im entering my driveway which is a slight slope
#87
comp mos ET25 with 235/40/17 toyo t1rs.
Cant check the old mans as its on stands![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Iv trimed the body kit back a fair bit and its still got issues? Iv sen people run the same as me with no issues at all.
I have no ARB so some people have put it down to that
#88
I'm sure if you fit an ARB that'll cure the issue. If you compare your rear to the other car you have and swap each component - springs, shocks, etc the only factor will be the ARB.
Surprised you didn't mention that you have no ARB at the start of this thread![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Charlie
Charlie
#90
my next question is would the arb stop the car squatting as much on the road as when I had the avo and ahmed springs the tyres were rubbing away at the body kit when id hit a dip in the road etc so will the arb help this?
#91
Caraholic
When you say the "same" do you mean "similar" or EXACTLY the same?
The shoulders on the Toyos may be a lot squarer than other makes or the width may be wider than stated. For example, the 235/40x17 R888 is actually 245mm wide.....
#92
Only if the ground is uneven or you are driving up it at an unusual angle, otherwise the suspension should compress equally?
When you say the "same" do you mean "similar" or EXACTLY the same?![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
and how do i find out if the width or shoulder is more squarer?
I havent driven the car with the custom springs so cant determine if there going to catch yet but the reason i cant deterime this is cus i cant get the car out the drive
#94
So no i can get out with these the same as the others if i force it out ie put it in reverse and make it move backwards thats how i did it with the others but iv just refitted my bodykit and dont want to damage it
#102
I know they mount diffrently there mate.. I beter try and get some drop brackets sorted aswel
How does it mount into the chassis? and can you also get poly bushes for the ARB?
#106
Caraholic
Any Whiteline distributor in Oz
. Do a search on Google, or if you are that much of a drongo
, then I can supply them, but seems a bit silly them being shipped all the way from Oz to a UK distributor, only to be shipped all the way back
. I can even give you the ref you need for the correct length
. Could it be any more simple?
#116
I have an escos arb here mate if you want it - no brackets for it though but I am sure we could work something out with other brackets. Paul has my 3 dr arb i think if you hassle him.
Just tried to call you and left a message but not on the mobile you called me with - and old number but your voice still on message bank.
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
Marc sierra
12
30-08-2015 10:38 AM
