FREE FILTHY PORN.....
Old 02-02-2005, 08:52 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
Default FREE FILTHY PORN.....
scroll down
now i have you attension.....
will a 2WD cos fuel pump fit in m6 escort tank??
please
anyone???????????????????????????????????????????? ???
Old 02-02-2005, 08:57 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
No. 2wd pump is a gravity fed pump that lives outside the tank . You could feed that standard lift pump straight into the gravity one though, which would be okay for around 300bhp .
Old 02-02-2005, 09:14 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
right o... cheers mike
and how the fook is that achived??
also, how will it give more pressure?
is it case of a bit of fuel hose from existing pump to 2wd one, then 2wd one to normal fuel line?
what about the fuel return??
you got any diagrams at all mate??
Old 02-02-2005, 10:02 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
Old 02-02-2005, 10:07 AM
Mike Rainbird
Caraholic
The fuel return would be as is, you're just adding the gravity pump into the system, that gives it the required flow you are after. Nothing else changes.
I had this set up on my Escort running 400bhp (lift pump feed direct into 044 gravity pump). I only changed the lift pump to feed in to a swirl pot before hand, when I fitted the eight 803s...
Old 02-02-2005, 10:09 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
ok mike, so what you are saying is basically stick the 2wd one inline with whats on the car at the mo??
and thats it?
cheers btw lol
Old 02-02-2005, 10:10 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
oh ah, and how would the second pump be powered?
just splice off from the in tank loom connector??
Old 02-02-2005, 10:17 AM
Mike Rainbird
Caraholic
Dan,
Yep that's it.
It would be best to give it a seperate power supply with it's own relay etc...
R4N SS
R4N SS's Avatar
cooont
Old 02-02-2005, 10:20 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
soz ran lol.
mike, would i still go via the fuse box for the existing pump?? have an inline fuse and what else would the relay go to? switched ignition?
cant think at the mo....
Old 02-02-2005, 10:24 AM
Mike Rainbird
Caraholic
The Escort Cossie has seperate relays for the fuel pump that are not in the fuse box, so it is easy. However, just use your common sense and make sure it is correctly fused and wired up to an ignition live as the OE item.
Old 02-02-2005, 10:25 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
thanks for your time mike
cheers
Old 02-02-2005, 10:29 AM
darren.cudd
darren.cudd's Avatar
mike you feeling ok? you just did a whole 3 replies without using the . icon
Old 02-02-2005, 10:31 AM
Mike Rainbird
Caraholic
I don't usually use the when providing technical info, so .
I only use the , when taking the piss / bantering with eejits , so
Old 02-02-2005, 10:38 AM
darren.cudd
thats better
oh and mike.....
Old 02-02-2005, 10:41 AM
mattbibs
mattbibs's Avatar
now where is the filthy porn??
Old 02-02-2005, 10:44 AM
JAP CRAP
JAP CRAP's Avatar
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
you have NEVER posted a reply to me without the ... :
Old 02-02-2005, 10:46 AM
darren.cudd
lets not forget mikes personal favourate
Old 02-02-2005, 10:54 AM
JAP CRAP
JAP CRAP's Avatar
Old 02-02-2005, 10:56 AM
darren.cudd
i think that calls for a.....
Old 02-02-2005, 11:02 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
oh dear
Old 02-02-2005, 02:15 PM
Mike Rainbird
Caraholic
That's because you're the BIGGEST eejit out there . I don't know anyone as indecisive as you, and that includes all my female friends .
You can't even decide what to do about a set of fucking hoses .
tankybaby66
06-02-2016 02:24 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
muzzman1
30-09-2015 08:59 PM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Quick Reply: FREE FILTHY PORN.....
