whats the correct way to set.....
Old 01-02-2005, 07:18 PM
GARETH T
GARETH T's Avatar
Default whats the correct way to set.....
whats the correct way to set a 4x4 tps?
i measyre votage at the ecy connector between pin 17 and earth, 0.6volts at o% and 4.6volts at fullt throttle! am i right in doing this?
for some reason im douting myself
Old 01-02-2005, 07:25 PM
ImaRacing 700
ImaRacing 700's Avatar
4X4 needs to be set to 3% of throttle on the pectal moniter....
Old 01-02-2005, 07:26 PM
GARETH T
GARETH T's Avatar
i havent got a pectel monitor no more,
Old 01-02-2005, 07:29 PM
Billabong
Billabong's Avatar
Why 3% and not 2% or 4%??
Old 01-02-2005, 07:31 PM
ImaRacing 700
3% is the lowest you'd get it stable....in my experience...only on 4x4 TPS though.
Old 01-02-2005, 08:20 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
0.2 - 0.25volts at idle is the important part Gareth.
0.6 is well documented but has been found to be out of tolerance with some ecu's and the 0.2 figure suits all.
Old 01-02-2005, 08:23 PM
Billabong
Billabong's Avatar
Mine's stable at 2%
Sorry to interfere with the post Gareth.
Old 01-02-2005, 09:44 PM
ImaRacing 700
Well Billy arnt you lucky
Old 01-02-2005, 09:47 PM
SeanT
SeanT's Avatar
Can you not set it the same way you do the 24v lump, disconnect ISCV and set for a certain number of revs at idle (it's 775-825 on the EEC-IV 24v V6)
Much easier than mucking about with multimeter and wrecking your multiplugs
Old 01-02-2005, 10:34 PM
Andreas
Andreas's Avatar
Why % when it displays degrees?
Old 02-02-2005, 01:44 PM
GARETH T
GARETH T's Avatar
this is why im questioning myself i car dont like 0.6
thanks
Old 02-02-2005, 02:29 PM
Spiky
Spiky's Avatar
woohoo, will be able to set mine tonight using this method then
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Brickhouse
14
03-10-2015 07:28 PM
OrionRST200bhp
29-09-2015 08:30 PM
Fiddy
21
29-09-2015 06:10 PM
RSmark84
13-09-2015 01:29 PM
Quick Reply: whats the correct way to set.....
