Changing out a lock set?
on a fiesta mk5 (2002)
as theres only 1 key with my GF's car, would changing out the lock set make a difference apart from having 2 keys?
how would the immobiliser bit work?
even if u bought a lock set you still gonna have to go through the procedure of paying to get the new ones re-coded as they dont come 'ready to go' even though its a brand new lock set so cheapest option is get 2 keys cut and reprogrammed for your existing locks
Gary Krishna
Not really mate.
Probably cost about 10 - 15 quid for a key and you there are places that can program a key for you.
Not sure on costs but you will have to get keys programmed if you change the lock set.
Why go to all the hassle of doing that when you can just get another key done?
Gary Krishna
Not really mate.
my mates dad who works in a ford garage was mentioning some prices the other night £££, i don't really want to go to a dealer
i did phone up a locksmith and he said it depended on the key we have as to whether he can copy it or not
theres only 1 key and the guy asked what colour of chip was on it, we pick the car up tonight, so i'll phone the locksmith tomorrow and ask him if their able to cut & program the key
st170 breaking
doesnt matter, see a few lock guys if 1 say sno
as in another thread titled 'how safe is your car'
if you have the right kit its easy to do
most have a ford code copier nowadays
lockset new will be 100+ and then coding
Gary Krishna
There's either red or blue coloured chip covers, the blue being the later ones.
When I used to work for a Ford dealer, we used to just use the WDS diagnostic system to do program the keys (don't know what system they use now, I left in 2004).
Neither were any different or harder than the other to do iirc.
Re your thread the other day you simply need to get another key cut, you seem to be wanting to complicate the issue. The new key won't be to expensive to cut and it is DIY to program.
The tab is simply the transponder, the colour I guess denotes the different generations as said.
Martin
Martin
Martin
Martin
Nope the key you have at the moment will be black and will have most likely a blue transponder in the top of the key, this is the key you need to initiaze "Learning Mode" this in turn will allow the car to learn your new key, you need a paired key otherwise people could just come along and program new keys and steal your car
The red master key I was talking about is for older PATS systems found on older Fords, just saying out of interest nothing to do with yours
Martin
Martin
after reading your post from the other thread (above) you mentioned you just need the 1 key, which is great, then you mentioned you need a paired key, which has probably confused me a wee bit.
but thanks for your input & info
i used to chap in nails for a living, so left the car mechanicing for others
he only has one key so cant do the simple diy method himself, if he had the solid red key he could, but only black with red dot so it needs a proper reprogramming
yep thats correct martin, red dot in key = red master key and older pats system. Unfortunatley he needs the red key to enable 'slave' keys to be reprogrammed. otherwise its a machine job
Red_bull
09-08-2015 08:34 AM
