24v boa engine bays
10-12-2010, 07:04 PM
24v boa engine bays
can you post pics of your engines, so i can see wot i dont need on the engine. cheers
10-12-2010, 07:23 PM
TT T38 Power
10-12-2010, 07:33 PM
10-12-2010, 07:36 PM
You should never have sold that bro
10-12-2010, 07:54 PM
TT T38 Power
Quote:
Originally Posted by
mark_24v_wiring
I know, don't know why i did to be honest
Steve
10-12-2010, 08:02 PM
one of my transit 24v's i have had
and a capri
10-12-2010, 09:05 PM
10-12-2010, 09:45 PM
10-12-2010, 10:30 PM
11-12-2010, 11:53 AM
Cossie Brad, I assume your going multi-point jetting, not single point straight into the intake?
11-12-2010, 03:12 PM
good pics, very usefull. which throttle cables have you used? sierra or granny? and which clutch cable? im putting one in a 3dr sierra.cheers gaz.
11-12-2010, 05:18 PM
granny throttle cable and a 2.9 4x4 clutch cable with mt75 hybrid box, yellow clutch ratchet.
11-12-2010, 07:27 PM
Turbocharging Technician
12-12-2010, 05:18 PM
no its running single point wet shot at the mo, would like to swap to multi point though!
12-12-2010, 05:35 PM
ELASTIC BAND
14-12-2010, 11:20 AM
Using a granny throttle pedal and cable on mine the pedal bolted straight in, and a xr4x4 clutch cable with mt75 rwd box made up of a 95 scorpio td and 2.9 4x4 bellhousing.
14-12-2010, 11:25 AM
Anyone know where would be the best place to get some free flow exhaust manifolds for these BOAs? The cheaper the better! Lmao
14-12-2010, 01:27 PM
cossie brad
Are the std ones that restrictive? i thought it was the inlet manifold that stopped the car making big power NA? i run std ex/inlet manifolds at around 300bhp, and the car pulls hard all the way to the 6000 rev limmiter
14-12-2010, 06:27 PM
cossie brad
ive ask this before and it seems for the money they cost they dont make that much difference to the standard manifolds.
14-12-2010, 06:32 PM
the 2 small black pipes that come out of the right hand side of the plueim just after the throttle valve.do i need them/ can they just be blanked off ? cheers gaz.
14-12-2010, 07:26 PM
mick
that air filter off a subaru?
14-12-2010, 07:33 PM
no idea tbh..
as for the two pipes , i don't use them just a bit of vacuum pipe joining them up...
16-12-2010, 03:56 PM
mick
no idea tbh..
thank you.
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
3drRich
13-09-2015 07:32 PM
mint_s2
02-09-2015 08:58 AM
RSmark84
20
24-08-2015 02:17 AM
track.focus'd
12-08-2015 05:53 PM
24v ,
29 ,
bay ,
boa ,
capri ,
car ,
engine ,
engines ,
inlet ,
m3cutters ,
manifold ,
passionford ,
sierra
