Fuel swirl pot pics and info please
Mk3 van efi turbo fitted, bigger outlet welded to tank but tank has no swirl pot, so i think i need to fit an external swirl pot, but am unsure on size, location, plumbing etc
has anyone fitted one on a escort van? i have the standard rst pump, im not worried about aero fittings etc, as its no extreme racer!
do you HAVE TO use two pumps?
![](https://passionford.com/forum/images/smilies/roi.gif)
funnily enough i am currently fitting a 1.6 efi turbo into my escort van pickup mk4 as the original engine is a 1.3 carb it has mech fuel pump and no return did you have to weld a return onto the tank? and from what i know you need a low pressure pump to feed fuel to the swirl pot and a high pressure pump from the pot to supply the injectors and pressure reg
..BS Motorsport..
is there a way of doing this without going for a full on boot mounted install? Noticed my alleged 's2' tank doesnt have a swirl pot in so going to need a swirl pot of sorts fitting somewhere.
I dont see why it cant be mounted under the van only problem is clearance and does any one know if thez can be used on there side as i am toying with the same idea
borboyous
22-08-2015 11:17 AM
blakey100
04-08-2015 08:17 PM
