VW Sharan Problem
Old Oct 22, 2010 | 02:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default VW Sharan Problem
The wifes bus (Sharan 1.9 TD) keeps having the turbo cut out
If you turn the ignition off then back on the turbo kicks in again, but sometimes it just keeps dropping out all the time.
Also sometimes its perfect.
Anybody got any ideas ?
I have swapped the air flow meter and boost solenoid with a mates but its still the same
Steve
Old Oct 22, 2010 | 03:21 PM
the mk1 kid's Avatar
the mk1 kid
Sounds like its going into limp mode, and needs the ecu read. It might bring up an error code 17965 Positive deviation - relating to boost. This is common, and used to happen on my passat, and is caused when the soot builds up in the turbo and causes the parts inside the turbo (VNT) that direct the flow in, or around the turbine to stick, causing too much boost created, and the ECU to panic.
You can buy basic copies of VAGCOM cheaply off ebay that will enable you to read the faults but no more...
Tom
Old Oct 22, 2010 | 03:44 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thanks for the reply
Its just a old R plate so no VNT turbo on this old bus
Steve
Old Oct 22, 2010 | 03:49 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
As above, it could be sticking flaps in the turbo but another possibility is a split or collapsing vacuum hose. The VAG diesels I have found in the past are very sensitive to any sort of split in a hose or when they come off.
A common thing that used to happen was the hose connection on the vacuum damper (a spherical shaped thingy) at the front of the engine used to break and cause poor response and lack of power like the turbo wasn't working. I've replaced a few of those in the past.
Check every little pipe you can see carefully, some of them are a little tricky to get to but are worth checking!
Old Oct 22, 2010 | 03:50 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Steve
Defo check all the pipes then!
They do turn to shit over a few years!
Old Oct 22, 2010 | 04:24 PM
RichieST's Avatar
RichieST
MAP sensors fail on these quite commonly, could be worth looking at.
Old Oct 22, 2010 | 06:02 PM
fraser9764's Avatar
fraser9764
yep, i had a vacuum hose come off on my vw transporter 2.5tdi, was quite worrying flying down a hill towards the back of a car at the traffic lights with no servo assisted brakes!
bit different but still check the hoses, need to replace the rest of mine as they all look pretty fooked and thats only on a 52 plate, it has been to the moon and back though.
Old Oct 22, 2010 | 06:58 PM
packman's Avatar
packman
Done one the other day , at the bottom of the fuel pump there is 2 small wires in a shroud this is for the enritchment when it comes onto boost, this had been rubbin on the fuel pump bracket and they had broke.. Its a bit fiddly but i soldered them back together and i got the boost back again.
Old Oct 22, 2010 | 07:09 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
have a look at this it may help u
http://www.google.co.uk/url?q=http:/...HrvNrWEo3AX1wQ
Old Oct 22, 2010 | 07:11 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
My transit has done 249k (02 reg), and my mates lt35 tdi (p reg) has done 280k, has yours done more miles?
Old Oct 22, 2010 | 08:55 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thanks for the advice lads
Will have a look on Sunday
Steve
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
