Tyre pressure on track, slicks and road tyres
Old 26-01-2005, 01:43 PM
Spiky
Spiky's Avatar
Default Tyre pressure on track, slicks and road tyres
ok
if using normal road tyres what should i set the pressure to before going out on track
and again if using slicks what should my tyre pressure be
Old 26-01-2005, 01:59 PM
keithG666
keithG666's Avatar
dunno...but get a LASER BEAM temperature gun, to check your tyres after a couple of hot laps!!!
this should help you see if the pressure is too high / low............APPARENTLY!!!
Old 26-01-2005, 02:00 PM
Spiky
Spiky's Avatar
i assume my slicks will be hot and VERY stick
but need to know pressure's before i get on track
Old 26-01-2005, 02:02 PM
keithG666
keithG666's Avatar
Then i have no idea!!
Old 26-01-2005, 02:46 PM
Oranoco
Oranoco's Avatar
I was told a while ago that you should run the tyres slightly harder than you would on the road to reduce sidewall flex.
Old 26-01-2005, 02:49 PM
AlexF
AlexF's Avatar
try 30 psi as a start point on road tyres...
and 15 psi on slicks!
alex
tracktoy
tracktoy's Avatar
im sure i was told slightly lower due to the air in the wheel expanding when it gets hot, so i would like to know this too
Old 26-01-2005, 04:37 PM
RichardPON
RichardPON's Avatar
Spiky,
Don't start too high as your tyre pressure will rise quite a lot on slicks.
I THINK I ran about 22 and 24 front and rear, but I may be well off - it's been a very long time
Old 26-01-2005, 04:39 PM
NUTS RuS
NUTS RuS's Avatar
What compound you got ??
Trust me to ask the teccy question first lol
Old 26-01-2005, 04:41 PM
Spiky
Spiky's Avatar
they black and say pzero on them
need any more info???
i'll be down there later, i might drop you a bell so you can tell me what to look for on the tyres, that ok?????
Old 26-01-2005, 04:48 PM
NUTS RuS
NUTS RuS's Avatar
Just write it all down and post here as Im out later
Pirelli's so far from that info.... should be ideally run at 24 - 26 cold and 30 hot - but if they are soft compounds then its all a different set of figures.
Old 26-01-2005, 04:50 PM
Spiky
Spiky's Avatar
ok will look later.
caio for now
Old 26-01-2005, 04:53 PM
markk
markk's Avatar
for a general rule for slicks , you DO NOT run higher pressures at all on anything to start , but , slicks , the front of your car is heavier than the rear , so a slight increase on the front over the back , so if were looking at something like 220's then i would start at 26 front and 24 rear , and work from that, if your getting bad feelings back from the cars handling adjust accordingly !!
does that make sence ??
do not run them too low or you will fook them in a lap at speed !!
as for road tyres - just dont bother with them - ther shite !!
Old 26-01-2005, 05:05 PM
CliffRS4
CliffRS4's Avatar
I too would like to know this please.
Am gonna be running 205/40 17's , yoko A539's (road tyres)
Old 26-01-2005, 05:11 PM
NUTS RuS
NUTS RuS's Avatar
Agree with all that Mark - especially the road tyres comment
I can feel a vast difference in performance of my tyres if they drop down just 3 psi from where I normally run them at.
The key is to keep checking and adjusting ALL day to keep them optimum.
Old 26-01-2005, 05:14 PM
markk
markk's Avatar
NUTS RuS,
AMEN!!!
what i do find very funny is the people who turn up to events with no tyre guage and no means to blow tyres up
Old 26-01-2005, 05:22 PM
tracktoy
tracktoy's Avatar
mine are 220-625-16 Dunlop CR311 x12
Old 26-01-2005, 05:32 PM
NUTS RuS
NUTS RuS's Avatar
x12 is a soft to mid range moulded slick, will take about 2 laps to get up to temperature.
Dunlops I find (on my car) run better if set slightly higher than others as the sidewall is not quite as strong. Only marginally tho'.
Old 26-01-2005, 05:39 PM
tracktoy
tracktoy's Avatar
cheers!!!
Old 26-01-2005, 10:14 PM
AlexF
AlexF's Avatar
NUTS RuS,
AMEN!!!
Thats me!! lol
Luckily Rus has a compressor in the can
ossie cossie
57
21-11-2022 10:05 AM
JK12
33
26-04-2021 12:09 PM
yatta
21-05-2016 10:31 PM
CrOwSoN15
14
03-09-2015 12:21 PM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
Quick Reply: Tyre pressure on track, slicks and road tyres
