General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
my v reg focus got a brake light out,do i need acess through the boot to change it cos my boot is fooked,wont open with the key or the button so can i open it from the inside to change the bulb? help please
99% sure you can do it from inside, going to be a bit fiddly reaching over parcel shelf, unless it's a saloon version in which case you're screwed!!
Pull the trim panel off at the bottom of the boot and you should see the lock and striker no probs.theres a cable connecting it to the lock barrel/motor.
Give it a quick pull and the boot should pop ok then.try dousing the cable in wd40 and it should go again.you may find that the fuse supplying the boot lock has blown due to it being to stiff to move........stiff like when you bum her!!!
