which tps to use
09-09-2010, 10:04 PM
which tps to use
i need to get a tps sorted for my saff ,it will be running autronic sm4 and a small turbo inlet and throttle body,and am unsure on which on one to get
any help apprecciated
09-09-2010, 10:39 PM
Quote:
Originally Posted by
james kiely
I think you can use the st escos one mate on the autronic,dont hold me to that though..
cheers danny
10-09-2010, 08:11 AM
The SM4 will work on the standard Tps, its the air temp sensor in the inlet manifold that needs to be changed
10-09-2010, 02:43 PM
cheers guys ,i take it you mean the standard small turbo one ,
what mods are required to the throttle body to run the anti lag on a small turbo throttle body?
does the iscv stay standard aswell ?
niall what sensor do i use instead
10-09-2010, 02:47 PM
escort rst cosworth rep
speak to jano ( oddkidcreations )
10-09-2010, 05:39 PM
bttt
10-09-2010, 05:45 PM
I don't know but assume the autronic can run inverted tps, so either will be fine.
10-09-2010, 05:47 PM
abetha has the small turbo one got a stepper motor in it ?
10-09-2010, 06:02 PM
speak to mark @ MAD, he might be able to sort the TB for antilag aswel james, the sapphire must be nearly done james?
10-09-2010, 06:13 PM
not even started andy
10-09-2010, 06:33 PM
oh your getting all the bits together then start build james?
long shot but you hardly know a man in bally shannon that owns mike rainbirds old shell? an has a brand new sapphire shell aswel? he had leda's for a 2wd need refub for 250 euro?
10-09-2010, 07:24 PM
no i dont andy but i was talking to a mate of his during the week
11-09-2010, 08:49 AM
bttt
am i right in assuming the small turbo escos used a pf09 tps
11-09-2010, 09:47 AM
You want a pf09 - not sure if that is small turbo (I would say 4x4 or BT). AFAIK Autronic gets cranky with the pf01 (goes open circuit).
11-09-2010, 10:41 AM
lincoln does the pf09 fit the small turbo throttle body?
11-09-2010, 10:49 AM
No idea sorry - I have a mate with one - i will ask.
11-09-2010, 11:11 AM
cheers lincoln
11-09-2010, 04:33 PM
bttt
11-09-2010, 08:59 PM
12-09-2010, 06:01 PM
james kiely
pf09 wiil not got on a ecc4 throttle body without some mods.
12-09-2010, 06:10 PM
13-09-2010, 08:20 AM
you need to file some alli of the plenum also some of the tps. you need to get an adapter made so when the throttle is opened it operates the tps. (thats a pain)
14-09-2010, 10:01 PM
a rs licker
a rs licker
cheers for the info mate
DixieTheKid
11
06-06-2020 11:20 AM
muffster
13
03-09-2015 09:40 PM
cozzy jeff
31-08-2015 04:14 PM
kosienutter
31
22-08-2015 09:55 AM
Roosie
15-08-2015 08:09 PM
