1.1 hcs engine problem
Old Aug 1, 2010 | 10:38 AM
potterpotta's Avatar
potterpotta
Default 1.1 hcs engine problem
i have a problem with my 1.1 hcs engine it will start with no trouble but once you try to accelerate it will just try to cut out but once up to normal temperature its fine does any body have any advice or clues on what is causing it thanks chris
Old Aug 1, 2010 | 10:51 AM
rsfido_1989's Avatar
rsfido_1989
has it manual choke or auto?
Old Aug 1, 2010 | 10:56 AM
potterpotta
hi its auto choke
Old Aug 1, 2010 | 02:44 PM
rsfido_1989
would say chokes not working correct as when its upto temp choke isnt needed but when started choke is due to slightly more fueling needed,
Old Aug 1, 2010 | 03:07 PM
potterpotta
do you know where the choke is located thanks chris
Old Aug 1, 2010 | 03:25 PM
rsfido_1989
tbh my best advise is to buy a haynes manual. Im not being sarcastic in anyway but read that, i had one for mine and i ended up doing engine conversions as it help me learn but check was all good.
Old Aug 1, 2010 | 05:43 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
If you've recently fitted a K&N filter to it, that might be the problem. I did that to mine when I had it years ago and experienced the same symptoms as you describe.
Old Aug 1, 2010 | 07:11 PM
potterpotta
there is a fuel return pipe on the front of the carb that goes to the fuel tank i think we have put a a hose clip on and tightened it a bit and that seems to solve the problem at the moment so not sure what to do next
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
