Throttle bodies and tourque - this worth doing?
i was having a look last night and i reckon i got enough room to have the airbox mounted at 90 degrees to the throttle bodies using silicon hose.
would this give much more tourque than having the airbox on the end of the tb's?? and is it worth doing?
scuse the shite pic lol...
any info appreciated
ive got a k&n universal airbox that goes over all 4 trumpets, and as i understand, the longer the better for the trumpets, so the silicon is in effect making the trumpet longer.
all the trumpets are the length of the outer shorted 2 cos thats all the room i have, unless i do the 90 degree thing
and the bend might act as if it was shorter,,,, best bet is to get too a rollign road with a couple of different setups and try them
If you wanted to be really fancy you could make a set of telescopic bell mouths to alter the tuned length at different rpms.
These could either be controled with a stepper motor and some sort of ECU out put or pulled out by by vacum against a spring.
With no vacum (high rpm/load) the spring would pull them short and at lower rpm/load the vacum would act aginst the spring and pull them out to full extension.
The ECU out put would be better as it would be more mappable.
Whatdya think????????
lol i think thats way too complicated, kinda like the ST170 inlet.. hmmm
dont think i got enough space for all that anyway...
the reason of this post is cos in the top pic i done, thats all the space there is, short trumpet and airbox.
but if i had the airbox at 90 degrees i could make the inlet tract longer...
mk3ste
17-10-2021 10:09 AM
