trickle charger
a decent battery should hold its charge for at least 6 months, alarms draw very little current when in an armed mode. so i would investigate as to whether you have a problem with something flattening your battery?
if there are no issues, then machine mart is a good place for these devices, thats where i picked up one for my dads motorhome about a year ago
cossie fan (unluckerly)
i do run 2 amps aswell and i have been known to listen to it when the car isnt running so im sure that wont help my situation i have a phone kit but its wired to a switched live other than that i cant think what else could drain it, were do i begin to check? i have a multi metre and a bit of knowledge....
CheeRS
Craig
CheeRS
Craig
CheeRS
Craig
CheeRS
Craig
You DON'T want a trickle charger, this will harm your battery, you want a battery conditioner, the c tek are excellent, a while back lidl had some awsome ones on offer, for £15, all the insides were siemens so quality item, have one myself.
The battery conditioners do exactly that they cycle between charge and discharge, the added bonus is they most have a battery reconditioner circuit too, whiucb does work and can revive most "dead"(due to suplhate) batteries, but will exercise any battery to get it's best, although very low amps, due to the way they charge(pulse) they charge much quicker than conventional chargers.
These are TOTALLY safe and can be left on 20 years if you like, a constant trickle supply, unless by chance it matches precisely the draw will cause minor damage over time.
No way in a million years will a fully charge battery start a cossie after 6 months even if left disconnected, natural drain on a std lead acid, lead/calcium, or calcium/calcium is around 1% per day at ideal temps, a lot more if cold.
The other alternative is to get a AGM battery but £130 of thereabouts, but decent ones ie spirally wound have less than 3% loss per month, so may be a better bet as more convenient, and a huge amount more powerful too.
DOO
27
27-11-2005 09:11 AM
RS Bowk
22
30-09-2005 10:52 PM
