injectors recoded
Old Jul 4, 2010 | 05:41 PM
sdk72's Avatar
sdk72
Angry injectors recoded
hi all,
quick question re: recoding injectors! I have had them recoded following a limp home episode and the car ran fine. took it out today and low and behold power dropped and limped home, flashing coil light etc. Does this mean injectors are goosed? i had diag of P2336(i think) which prompted me to get injectors recoded and as I say, the car ran fine for a few days, i have read somewhere that you have to run the car for 5 miles when fitted , is this true and could this be the case of he latest limp home mode/
any thoughts gratefully accepted
steve
Old Jul 4, 2010 | 05:47 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
A recode is very seldom a fix, it just delays the inevitable. P2336 would suggest that injector number 1 needs replacing.
You may be lucky and get away with one, but it's very common for them to go 'together', so you could fix that and find that number 3 goes in a couple of weeks, and so on.
Old Jul 4, 2010 | 05:50 PM
Bloody modern cars they are ok when they work but when they go wrong they can be a nightmare.
Old Jul 4, 2010 | 05:53 PM
DanW@FastFord
Spelling Club King!
Tell me about it! My Mondeo is the newest, lowest mileage car I've ever owned, and is by far the most unreliable, and costly to fix.
Old Jul 4, 2010 | 06:28 PM
billybigspuds's Avatar
billybigspuds
yes threy need replacing or atleast the offending one
Old Jul 4, 2010 | 06:30 PM
sdk72's Avatar
sdk72
i figured that migjt be the case. next question is : where is the best , best being chepaest, place to get one of these buggers. i am based in lancs. cheers
sdk72's Avatar
sdk72
sorry about the spelling think I need a drink
Old Jul 4, 2010 | 06:38 PM
botters's Avatar
botters
competant bodger
merlins walton summit preston
or diesel bobs ribchester
Old Jul 4, 2010 | 06:51 PM
rs_turbo_tony's Avatar
rs_turbo_tony
hi all,
steve
injectors on wot car mate
Old Jul 4, 2010 | 07:14 PM
sdk72's Avatar
sdk72
the evil 2002 mondy tdci 130
Old Jul 4, 2010 | 07:21 PM
Gadget's Avatar
Gadget
Spanner monkey
Ive just sent my four away for rebuilding. Had them ultra sonically cleaned but the fault remained. Before hand, i've replaced the fuel filter, fuel metering valve, fuel temperature switch, fuel pressure regulator and had the injectors cleaned. The rebuild should cure the fault, BUT, if it doesn't, the only thing left is the high pressure pump so fingers crossed LOL
Old Jul 4, 2010 | 07:41 PM
rs_turbo_tony
nice i work for jaguar dealer you need need to carry out spill off test ,no good replacing one injector ,u need to replace all four and high pressure pipes then carry out reprogramming
Old Jul 4, 2010 | 08:21 PM
vaughant's Avatar
vaughant
could try ebay as well for the parts,probably loads on there doing them,they about Ł100 a piece iirc?
Old Jul 4, 2010 | 08:35 PM
cozzy940's Avatar
cozzy940
ebay
Old Jul 4, 2010 | 09:32 PM
DanW@FastFord
Spelling Club King!
Sonic cleaning's a bit pointless on common rail injectors, (from what I've been told anyhow). Did you send them to a Delphi dealer this time?
Old Jul 4, 2010 | 09:41 PM
THE RADMAN's Avatar
THE RADMAN
how are they coded and is it just deisels?
Old Jul 4, 2010 | 10:12 PM
macrs's Avatar
macrs
afraid i'd say new injectors mate.......
I've got a 2006 st tdci, 2.2. Started lumpy cold start and rough idle at only 37k, was still under warranty from buying it...Took it back to the dealers and they replaced them straight away, and also said it was piontless to consider recoding.
Car runs perfectly and pulls a freight train again.....
Sorry mate!!!!!!
Old Jul 4, 2010 | 11:19 PM
MarkyMark's Avatar
MarkyMark
coding is usually needed when new/different injectors are installed, i wouldnt trust the ones off ebay as they most probably will be second hand units who knows how long they will last. I used to be able to get hold off brand new injectors for 20quids each, sadly no longer
Old Jul 5, 2010 | 09:29 AM
sdk72's Avatar
sdk72
2quids each sounds bloody nice. I am looking at 200 quids eaach aren't I? will try the places mentioned, not sure I trust stuff on ebay - but will have a nosey anyway. can they be serviced at all???????
Old Jul 5, 2010 | 09:33 AM
MarkyMark's Avatar
MarkyMark
new yes iirc around 200each, not sure if you can service them, also there are two types of injectors both look the same but have different sized injectors on them, and both are found on mondeos so make sure you match up the part number
Old Jul 5, 2010 | 10:04 AM
gouch1's Avatar
gouch1
same old problems on these engines if its not injectors its pumps why do ford keep using the same shite surely its not good for there rep lol
all modern diesels seem to be the same
Old Jul 5, 2010 | 10:11 AM
sdk72's Avatar
sdk72
will do cheers pal. not sure the car is woryth it at 200 quid each !
Old Jul 5, 2010 | 10:21 AM
sdk72's Avatar
sdk72
should be illegal the amount of sh*t I've had with this car
Old Jul 5, 2010 | 11:03 AM
london_chris's Avatar
london_chris
if the car is switched off and back on does the fault disappear???
does it then drive ok for a while???
might be worth cleanign ur egr valve, as this has the same symptoms of your fault!?
better still blank the bastard valve off.
Old Jul 5, 2010 | 11:22 AM
DanW@FastFord
Spelling Club King!
It's very unlikely that the EGR on a 2002 TDCi would cause the EML light to come on, as they're not 'electrical' like the later EGRs.
Old Jul 5, 2010 | 11:48 AM
sdk72's Avatar
sdk72
I blanked the egr valve off as recommended by some of the guys on the forum. I have since unblanked it as there was a whistling / screaming noise coming from engine when accelerating. sounded awful
Old Jul 5, 2010 | 12:18 PM
sdk72's Avatar
sdk72
my mates took it to a garage today for me. just phoned to say that the car runs like a dream - no flashing lights etc. thats on the way to the garage, the garage did a diag for him and found no faults. aaaaaaaaaaaaaaaaarrrrrrrrgh! anyone want to buy a mondeo ????
Old Jul 5, 2010 | 02:18 PM
sdk72's Avatar
sdk72
got my mate to rag it a bit. its done it again. his mate said the egr can cause this.... watch this space
Old Jul 5, 2010 | 02:25 PM
sdk72's Avatar
sdk72
problem is setting off to fast or going over a ton and turbo cuts out! is this an egr problem???
Old Jul 5, 2010 | 02:46 PM
DanW@FastFord
Spelling Club King!
Not necessarily. It's also a common symptom of a pump issue, but it normally comes with the codes P0251 and P1211.
If blanking it didn't fix the fault, replacing it won't either!
Old Jul 5, 2010 | 03:00 PM
sdk72's Avatar
sdk72
no codes being returned. gonna get a new fuel filter methinks too.
Old Jul 5, 2010 | 03:09 PM
DanW@FastFord
Spelling Club King!
Yeah, mine's the same, no codes.
Make sure you fill the new filter with diesel when you refit, otherwise you'll have a hell of a job starting it!
Old Jul 5, 2010 | 03:14 PM
sdk72's Avatar
sdk72
whats up with yours then?? will defo fill it up
Old Jul 6, 2010 | 08:08 AM
Gadget's Avatar
Gadget
Spanner monkey
They were done at a delphi dealer / diesel injection specialist local to me, according to them, one was really blocked before cleaning and the spray was more of a dribble, Had them cleaned and made no difference.
Had a call from the bloke who's rebuilt my injectors yesterday saying that the control valves were all worn, two badly, the other two not so bad! Should have them before one o'clock today so will fit them later and take it for a test drive.
If anyone wants he's number pm me, done me a very good price and 3 day turnaround!
Old Jul 6, 2010 | 10:15 AM
sdk72's Avatar
sdk72
someone mentioned getting some diesel additive because of water content in the diesel and it helps shift it, increasing perfomance. is this right and does anyone know what it is?
cheers
Old Jul 6, 2010 | 10:40 AM
DanW@FastFord
Spelling Club King!
Had loads of aggro with injectors, even though car had had Ł1800 worth of pump and injectors just before I bought it and car's only done 78K miles. Developed v.bad diesel knock and smoking on start-up a month later. Delphi tested the injectors and said they were fine, yet swapping two cured the knock and reduced the smoke!! Cost me Ł600, and it's still not quite right now.
Plus I've got a serious boost leak and can't find it, despite stripping the car and swapping just about everything... no fault codes, and non of the usual suspects are at fault. Plus I've got a hub nut that works its way loose no matter what we do, and takes out wheel bearings which are Ł60 a pop. I'm on my third bearing, and 5th hubnut. Got an outer CV to swap in next, so fingers crossed for that.
Give it a go. There's a lot of hype about additives, and lots of different ones to choose between. Just don't expect it to be a magic fix for your car!
Old Jul 13, 2010 | 10:31 AM
sdk72's Avatar
sdk72
FFS, the car now goes in limp mode as and when it bloody feels like it BUT if you turn ignition off and then back on its fine again! Whats the cause of this peeps???
cheers
S
Old Jul 13, 2010 | 10:38 AM
billybigspuds
err...... the injectors?
unless its code p132a then its the turbo actuator
Old Jul 13, 2010 | 10:41 AM
sdk72's Avatar
sdk72
no code faults showing hence my question - turbo actuator, what be that then !
Old Jul 13, 2010 | 10:44 AM
DanW@FastFord
Spelling Club King!
cheers
S
Still injectors. Does it go into limp if you're a bit heavy footed, or at random? Injector/pump issues tend to go into limp if you accelerate firmly. Or does it still do it if you're really gentle with it? Worst case scenario is that it 'could' be the pump.
Could be time to trade it in, or punt it through an auction!
Not on a 2002 TDCi, they have 'mechanical' actuators, and don't log any fault codes.
