High Imp 440cc Fuel injectors
Can't help with car make and model, but got part numbers, if any use bosch 608 are 441.4cc, if that's any help, there's loads around that or even higher up to 1900cc with the car model listed but not if you want precisely 440cc, larger ones ok ?
Thats if i can find some VXR ones
Also found out that volvo do some Bosch 0280 155 968/ Volvo part number 9202100 Anyone know what model of volvo these are on?
What exactly do you need ?
440 or larger ?
440, cheap as chips
http://www.fiveomotorsport.com/domes...rs/?itemid=309
or the typical 600cc Siemens
http://www.fiveomotorsport.com/domes...rs/?itemid=290
Although there should be plenty of local suppliers for the latter.
440 or larger ?
440, cheap as chips
440cc larger should be ok
Cheap as chips if we can?
If we can find some second hand that would be good
My mates car is going on the dyno for mapping but he is worried that he might need bigger fuel injectors and this is the spec that he's been told he will need if the standard one max out
these are used on turbo volvo and the new ford focus rs , ford want £289 for 1 injector
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
also got mine from fiveomotorsports cheapest going imo
cheers paul
DixieTheKid
11
06-06-2020 11:20 AM
