Anyone know done a timing belt on a ecotec? Tensioner issues
the issue ive got is with this type:
basically you need to use a 6mm allan bolt to "untension" it so the lil arrow is all the way right. however when you do this you actually tension the the tension at the same time (as it has a tensioning system on the bolt)
so the bloody thing stays in the same place and doesnt do either....
im starting to loath this car so any helps greatly appreciated as its gotta be something IM doing wrong as surely vauxhall cant have ****ed up on this...
im starting to think about setting this car on fire and buying another car, ****ing shity vauxhalls
You use the allenkey hole to tension the belt then lock it off with the torx bolt mat hope this helps you shouldnt need to use the allenkey to slacken it off as it will be on a spring and when you relese the torx bolt it will relese the tensioner
i cant get the belt on mate
I just done one on a X22XE, engine(ecotec), as you say bloody nightmare, crap design, fortunately I was doing a w/pump on at same time(and advise you do ?), I left off one of the idler wheels at the side, around base of head area, then gently levered on, worked for me with lots of swearing thrown in.
i do these on a daily basis, fit all pullys as normal, leave tensioner bolt loose, fit belt and leave off on the inlet cam, now here is the tricky bit to explain, the pointer is an indicator of tension, the tensioner on these constantly apply pressure to belt as it wears, so with the pointer in the position it is in it has actually applied all of its tension, so just get your finger on the pointer and move it fully backwards, this effectively slackens the belt, so it gives you the ness. amount of belt to just slide it onto the inley pully, then turn you allen key so the pointer lines up and tighten tensioner bolt, most of the time the tensioner bolt rounds off coz there shit so i use a different bolt that i stock just for these!!
Heard these have a habit of snapping after 60k
Chain ?, no it was a a series "B" frontera(T reg), which uses a belt on me dads fronty, I think that is the engine code but may be wrong as not relaly used to vaux's, it is a 2.2 and says ecotec on the cover.
I did the BELT/tensioners/idler etc and water pump, as history was a bit scant, as it happened the "old" belt had by the looks just been done, but without knowing for sure played safe.
I just do the belts every 25,000 or 3 years which ever is first.
borboyous
22-08-2015 11:17 AM
