Anyone help with boost problem?
Old Jun 7, 2010 | 05:06 PM
mattseries2's Avatar
mattseries2
Default Anyone help with boost problem?
Evening all!
Ive posted about this before but still having the same problem!
Basicly had a bump in my S2 but only damage was front bumper and rad. Ever since ive fixed them the car wont boost up AT ALL! It dosnt sound like a boost leak beacause im not getting and "hissing" as you normally would. Ive had intercooler tested and its fine. Checked turbo/manifold/elbow etc and all looks like it should.
Anyone got and final ideas or what i can check before i take it to a tuner to get it looked at?
Starting too really peeeee me off now because weather is getting good and the S2 is sat in the garage!
Matt
Old Jun 7, 2010 | 05:25 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
any smoke and/or dodgy noises?
Old Jun 7, 2010 | 05:31 PM
mattseries2
Nope...no smoke or dodgy noises...hmmmmm
Old Jun 7, 2010 | 05:33 PM
Ebonycossie4x4
and you have looked at obvious things, Bar is not broken/bent on actuator? (from impact)
are you 100% there is not a split in a pipe?
Old Jun 7, 2010 | 05:38 PM
mattseries2
Nope all new boost pipes.
Im going to double check actuator, few other rst owners have said they have had a similar problem.
Old Jun 7, 2010 | 05:39 PM
S1's Avatar
S1
Does the compressor/impellor still spin round?
Old Jun 7, 2010 | 05:43 PM
Ebonycossie4x4
You mean when turned off i take it and turning by hand?
I would imagine he would hear a noise if there was a problem there.
get the actuator off and have a better look, possibly replace.
The accident could be a massive coincidence dont forget lol
Old Jun 7, 2010 | 05:57 PM
mattseries2
Turbo spins fine with no play.
Yeh i thought it might me just a coincidence lol but where the rad split it had hit the actuator so just had a look and it looks as if it was holding the penny wheel open...Actuator arm was very stiff (no in and out movement).
Old Jun 7, 2010 | 06:02 PM
tomS2-Rst's Avatar
tomS2-Rst
Does it have any boast at all? or do you have nothing.... you prob find damagd vac pipe as these wouldnt hiss. its prob somthing simple like that. check all vac pipe with a mitie gauge. (excuse my spelling)
Old Jun 7, 2010 | 06:04 PM
Ebonycossie4x4
why dont you pop the actuator off and make sure the arm/penny is not broken and spinning around.
should the wastegate not be held shut?
Old Jun 7, 2010 | 06:06 PM
Ebonycossie4x4
definitely check the small pipes from actuator and turbo. I would have thought he would have checked these already though.
youre not running a bleed valve are you?
Old Jun 7, 2010 | 06:18 PM
rich123's Avatar
rich123
your waste gate should be held shut untill it reaches your boost pressure,and then it lets the boost off ?
Old Jun 7, 2010 | 06:19 PM
Ebonycossie4x4
Thanks i thought i was right!
Old Jun 7, 2010 | 07:44 PM
mattseries2
Na not running a bleed valve. And yeh i checked all vac pipes for splits and they were all fine.
When i looked at the actuator arm it looked like its holding the wastgate open slightly...could the knock from the rad have caused this?
Old Jun 7, 2010 | 08:06 PM
rich123's Avatar
rich123
maybe the turbo is at the front of the car isn't it? i would say as above wip it off and have a look
Old Jun 7, 2010 | 08:15 PM
mattseries2
Yeh it is mate. Very close to the rad (actuator).
Old Jun 7, 2010 | 08:19 PM
Ebonycossie4x4
mate i would be looking at the actuator, could easily be the problem.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
