which cos next to do 200 then ? ? ?
Old 10-01-2005, 02:26 PM
  #241
martinrs500labatts
martinrs500labatts's Avatar
the ultima will be a little quicker round the bends lol
and they look very nice.
Old 10-01-2005, 02:37 PM
  #242
martinrs500labatts
Old 10-01-2005, 02:44 PM
  #243
Porkie
Porkie's Avatar
Originally Posted by 3drstretch
Originally Posted by Porkie
However the most impressive performance of 2005 for me was actually Simon Norris and his Evo. 200mph without GAS on his first attempt at Brunters and some simply awesome sprint times!
How do you know wot will be achieved this YEAR. That was last year.
in my ass!!!!
Old 10-01-2005, 02:54 PM
  #244
ImaRacing 700
ImaRacing 700's Avatar
Karl...you keep bangin on about how many miles your car has done ....I would certainly wager that the majority if not 99% of your driving is Miss Daisy as you cannot use the power on the road except up and down a motorway...So you say you done what 20k????Well that aint no technological feat!...Why dont you "really" see if its a good build by doin some events???As you do like to harp on about how clever you are!
Lets be honest i could easily hit 750bhp with the right turbo and if i only used it as a road car i'd get 100k out of it!!!!..If i competed it i'd get 50mile if that
Old 10-01-2005, 03:03 PM
  #245
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
The Ultimas are poo out of the box, compared how they SHOULD handle . Ahmed is building a twin turboed AJP8 engined one and has been measuring all the geometry etc - apparantly he was shocked at how poor it is from the factory - it's going to require quite a bit of re-engineering to get it right .
They do look good though .
Old 10-01-2005, 03:24 PM
  #246
Karl
Norris Motorsport
Karl's Avatar
Phil,
I'll agree with you just to humour you.
Old 10-01-2005, 03:30 PM
  #247
ImaRacing 700
You need to mate..as we all know you run a std T5 (well until recently if you changed for a proper box at last ) and we all know that it will break if you got a genuine 600bhp..which you say you been through a few by putting your foot down...so your engine aint properly tested...only that it is stronger than a T5 std box!..Which is only rated to 330 ft lbs torque aint it?
Old 10-01-2005, 03:43 PM
  #248
martinrs500labatts
mike,
they have made one with twin turboed hyabusia engines, its 1000 bhp and only 1000 kilos,
they have not evan timed this car, as they thought it would not be fair
Old 10-01-2005, 04:11 PM
  #249
sunny
sunny's Avatar
Yep TVR engine equipped with 2 T34's and external wastegates....well that was the plan a few months back. Knowing Ahm, he's probably changed his mind and made it a little more crazy now.
Old 10-01-2005, 04:57 PM
  #250
Karl
Norris Motorsport
Karl's Avatar
As said Philip I'll just agree with you as you always know best!!
Old 10-01-2005, 05:01 PM
  #251
ImaRacing 700
Yes Karl i certainly know i am right when YOU say that Puts your ass dyno into perspective dont it..seeing as you can only be running max @ 530bhp to hold the gears together.....cor thats a real test of engineering.....i think personally i will wait till you get a proper box and to some proper testing before i say that you can build a proper engine
Old 10-01-2005, 05:11 PM
  #252
I CAN actually see why Rod and Mark used NOS.
Rod like using his car on the road and so wanted it to be as Torquey and responsive as possible. To do 200mph without NOS will probably require a bigger Turbo than a GT35, and a powerband much higher up in the rev range which is not really what Rod likes as far as I understand.
His current engine is torquey low down and probably nice to use on the road and yet with NOS can still do 200mph at Brunters (that is VERY VERY fast)
So I can totally understand why they have done it.
Thats completely correct Porkie. Its a road car & used on a regular basis as such.
If I had wanted 700 peak Power off Nitrous Mark could supply that but it would not have been as nice to drive or as quick on the road.
My old conversion held the RWD Topspeed record with bugger all Power cos it had lots of Torque.
To do 200mph at Brunters in a full weight Saff requires around 700bhp at the revs that allow 200mph, Peak must be Higher, but to acclerate to 200 in 30s ( or run out of road) takes Huge Torque across the range. On Nitrous I have well over 600ft/lb from 4.2k to past 7.5k peaking around 650ft/lb.
750bhp/650ft/lb off Nitrous would be difficult to obtain in a road engine.
Hope this explains my reasons for doing what I did, much soul searching & 40 years of driving fast cars went into my Final Spec, but im 100% sure it was the correct one, This car is perfect, Thanks Mark. .
Rod
Old 10-01-2005, 05:31 PM
  #253
3drstretch
3drstretch's Avatar
Originally Posted by MADRod
The Top Ten fastest times ever run by Cossies have come from these two Tuners.
Rod
Is this quote entirely TRUE.Thought there have been some fast cars attending events such as TOTB that have been up there around the 180MPH mark(Martin Johnson,Andy RS,Nutter,Spadge etc)Or are you saying that there are 10 seperate cars that have done better than those mentioned.
Rod as you have come back to this thread any chance you could answer above Please.Where have you got your top 10 from???
Genuine question as i'm interested.
Old 10-01-2005, 05:37 PM
  #254
ImaRacing 700
I guess a car that has a rev limit of 9k could no way hit the limiter with 650bhp then as it wouldnt have the torque to do it.
Old 10-01-2005, 05:52 PM
  #255
Lee Reynolds
Lee Reynolds's Avatar
So rod did 202 at brunters which is short. Do we have any idea if it would do more on the motorway???? Whats is geared for Rod? (appologies if i have missed that bit)
Old 10-01-2005, 06:12 PM
  #256
righthooker
righthooker's Avatar
as far as i am concerned,ROD dont hold the record,just the keys to a fucking very quick car.
SO if i bought your car Rod would i hold the record
IT ainnt your record till you do it
On a serious note ,why dont you drive yourself?
Old 10-01-2005, 06:38 PM
  #257
M Brian
M Brian's Avatar
skill balls and experience of the driver so not to damage the car and get best results out of it.
iirc rods own top speed is still faster than the next nearest top speed.
Old 10-01-2005, 06:40 PM
  #258
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
This has been done to death folks, do a search
Why do people have to use this particular aspect to try and take away what Rod has achieved with his car?
Rods done 198. something MPH anyway, so hes personally driven faster than 99.5% of people on this forum, including myself, and with his mature years (no offence intended Rod) i find that fooking incredible TBH... so i dont see where people are going with this line of questioning that ALWAYS pops up...
Old 10-01-2005, 06:48 PM
  #259
How much shit do you actually speak phil.
Post the maths and reasons for this statement if you can
  #260
Big G
Big G's Avatar
Could have summat to do with his pacemaker throwin a wobbly at warp factor 9
Or could it be that his balls just aint that touch big enough, Mark has said previously that he intends to stop doing top speed runs due to the possible dangers (throwing a shaft etc) at 180+ in a taxi = muchos pain, and there aint much joy in that.
Old 10-01-2005, 07:07 PM
  #261
RANJ
RANJ's Avatar
FFS AS STU HAS POINTED OUT ROD HAS PROB DRIVEN FASTER THE MOST THE LAME FUCKWITTS WHOKEEP BRINGING UP THE SAME LAME SHITE rant over.....
Old 10-01-2005, 07:13 PM
  #262
Kev.H
Kev.H's Avatar
Originally Posted by RANJ
FFS AS Stu HAS POINTED OUT ROD HAS PROB DRIVEN FASTER THE MOST THE LAME FUCKWITTS WHOKEEP BRINGING UP THE SAME LAME SHITE rant over.....
But Ranj you started the post
Old 10-01-2005, 07:14 PM
  #263
RANJ
RANJ's Avatar
ie was talking about the clueless twits who go on about rod not driving
Old 10-01-2005, 07:19 PM
  #264
M Brian
M Brian's Avatar
:cry @ranj
youre going to need a new key board after pressing the keys that hard!!
thats if you aint thrown it out of the window already
Old 10-01-2005, 07:23 PM
  #265
Kev.H
Kev.H's Avatar
I think Rod proved everyone wrong on that and probably realised a dream too
Old 10-01-2005, 07:30 PM
  #266
Any time a complete asshole like you wants to come to Brunters & try to beat my 198.5 , I will be there. Will be past 200 in my latest Spec but will never beat Mark because he is 25 years younger & doesnt have the medical probs I have.
Adrian recently did 181.9 at Brunters & Mark did 185.5. He come over & shook my hand & said how the f**k did you do 198.5 down there, he was shaking like a leaf.
People like you talk Shite about something you Know nothing about & will never achieve.
Rod
Old 10-01-2005, 07:38 PM
  #267
Rod
Now thats a bold statement.
NEVER SAY NEVER to anyone rod cause you have no idea what the future holds.
  #268
RANJ
RANJ's Avatar
Rod
how many times have we heard that
Old 10-01-2005, 07:46 PM
  #269
Rod
Happy new year Dingy.
Mark can see into the Future as well as walk on water, its why I know
Righthooker aint going to ever run 200.
Old 10-01-2005, 07:48 PM
  #270
rod 5 years ago bet you never though you would.
Only nieve people have thoughts like that.
Not saying he will BUT you can't say HE wont....bet he has 40 years before he is your age.....40 years ago cars weren't going much over a oner.
Old 10-01-2005, 07:57 PM
  #271
Cant argue with that, your even thinking logically, 2005 may be a good year for you .
Got a bit annoyed with Righthooker, so withdraw the comment. .
Old 10-01-2005, 07:58 PM
  #272
Every year while i am alive is a good year regardless of what it brings.
Old 10-01-2005, 08:03 PM
  #273
As you may Know , I was very seriously ill 10 years ago, so I can agree with that, its why I do what I do with my car.
Live it now mate, you aint gauranteed next year.
Rod
Old 10-01-2005, 08:05 PM
  #274
Yeah and i nearly died in a motorbike accident @ 17 so i never take any other way of life but today.
Old 10-01-2005, 08:14 PM
  #275
Lee Reynolds
So rod do you think(or know) if on a longer road your car would do even more?
Old 10-01-2005, 08:19 PM
  #276
Porkie
Porkie's Avatar
Thats completely correct Porkie. Rod
See I'm not just a pretty face
Old 10-01-2005, 08:24 PM
  #277
CozzyBrom
CozzyBrom's Avatar
pork chop i fort u wanted to ring me
lol
Old 10-01-2005, 08:25 PM
  #278
Porkie
Porkie's Avatar
calling now!
  #279
Kev.H
Kev.H's Avatar
I thought its cos you could sing >???? cos you didnt get into Another Level on looks
Old 10-01-2005, 08:29 PM
  #280
Porkie
Porkie's Avatar
I'm a great singer! you must be 'outa ya mind' mate
Quick Reply: which cos next to do 200 then ? ? ?
