when fitting a L8 ecu into a 2wd car is it,,,,,,,
when fitting a l8 into a 2wd car should you change the idle speed control valve?
i know the diffence between them is the 4wd iscv is that is has an internal protection diode for back emf!
does the 2wd ecu have one fitted inside?
thanks for looking
thanks for looking
GARETH T, The L6 already has reverse EMF protection for the ISCV.
It just so happens that some later ISCV's have an additional diode as this valve is
used on other cars fitted with the weber IAW system (ferrari, fiat, lancia etc)
PassionFords Creator
Simon,
You may be able to help here then. The L6 and L8 items have a different part number. Are they perfectly interchangeable or not then as ive had unusual results a couple of times and to be honest, dont fully understand whats what with em.... fookin things
Originally Posted by saff_cossie
Stu - I dont think they are perfectly interchangeable size wise anyway. Mike R knows though.
Like the saff jacking point covers are now no longer available (Last used in 1993) i discovered last week when one piece of shit stole all mine
Thanksfully a cuastomer sold me a set for £10 yesterday
Simon,
that on some wiring looms the ISCV connections are reversed.
So if you put an ISCV with internal diode on such a reversed loom,
the effect is the diode shorts out the supply from the ecu and does not work.
In this situation, the valve wires should be reversed and all should be ok.
Simon,
Hmm..
There are deffo inconsistencies somewhere but there doesnt appear to be any rhyme or reason to it as i have both 2 and 4wd valves and they dont BOTH work ok on all 4x4s but they do on SOME
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
