PassionBMW help.....Carlos??
I've got a friend with an BMW 530i 52 plate (M54 engine), 100k on the clock.
Its losing approx 2 pints of water every 100miles or so.
He's taken it to a small garage & they've told him that its definately the headgasket and quoted him a small fortune to do it, I'm a little dubious though due to lack of other signs of headgasket failure - its in excellent condition, engine runs perfect, no missing on startup, no bubbles in expansion tank, no mayo in header cap, oil is clean too and level hasnt changed, doesnt overheat, temperature is bob on, no smoke out of exhaust.
I've told him I can do it for him but I'd like to have a look at it first so I'm taking it home tonight.
I think he's got a leak somewhere....after doing a bit of research apparently they are prone for the expansion tank cracking, or the water pump seal failing. Anywhere else that is common for them leaking from.
Cheers guys
Lee
P.S. I've got a block test kit coming so that I can test the coolant too!
Cheers guys
Lee
Yeh I thought so too.....looking down onto the undertray it does look wet I have to admit so I'll whip it off and have a look.
Alex....I'll probably rent them. Already bought the long E12 tool for headbolts. Have you got them?
Its not unheard of for these engines to do a headgasket at this mileage apparently!
Lee
Lee
Thats exactly what happened with my old 325ci & that was the head gasket, I was told by numerous people with good BMW knowledge that often if fucks the threads for the head bolts when trying to refit the head they wont pull down as the ally blocks are so soft? Not sure how true but the cheapest way in the end was to replace the whole engine!
Carlo, top of the class again!!
Drove home earlier and popped the bonnet for a nosey whilst it was up to temperature etc and low and behold there in the bottom right hand corner was drip drip drip!! So looks like its new radiator time then!!
Alex - yeah I saw the book time was around 15 hours according to autodata, but looks like I won't need to do it now! LOL!
He needs new brake discs too as the steering wheel vibrates like a bastard when you slow down from over 50 odd!!
Thanks again for the advice!!
chaged loads
the elec fan packs up and they over heat,then the rad looks like someone has blow it up ,
then run the car up and you should be able to see where its leaking from and check the rad ok as well
the easy way to check the elec fan is working,start the car up and turn the a/c on and see if it works
hope it help,
need any more help just ask
Nice one mate! Electric fan is working fine as it cut in and out a couple of times whilst I was nosing around!
Gonna get it on the 2 poster and drop the undertray off as it looked to be coming from the very bottom corner!!
I also heard that there's a temp sensor that can leak too, not sure if that's on the rad or elsewhere though!
Will look tomorrow tonight!!
The radiators are terrible for it we done a E39 on friday was the same wasnt pissing out tho only leaked when warm , the E46's also do it or the plastic bottle bursts on the side of the radiator but you know when that happens. Lucky you mate not a nice job as above to do a head gasket on these we dont do many, the engines are fairly bullet proof its silly things round about them that cause probs , coils,air flow meter,radiators or the heater resistor drains the battery all can be sorted fairly easy.
Dodgy bloody backstreet garages!!!
Carlo....
Does this look familiar....
![](http://img.photobucket.com/albums/v126/Lee_R21Turbo/P1030995.jpg)
Although its still very hard to see the exact place where its leaking but it appears to be about halfway up the radiator close to the plastic bracket area!!
...and what was I saying about the dodgy brakes...
![](http://img.photobucket.com/albums/v126/Lee_R21Turbo/P1030996.jpg)
Alps Pacino
17
06-12-2008 08:11 AM
topaz
49
10-06-2008 08:42 PM
