Wireless network problem...
Old Jan 5, 2005 | 08:43 PM
xpackcapri's Avatar
xpackcapri
Default Wireless network problem...
Old Jan 6, 2005 | 02:25 AM
NUTS RuS's Avatar
NUTS RuS
Im stood under the window waiting
But otherwise BTTT
Old Jan 6, 2005 | 03:47 AM
Steve200+'s Avatar
Steve200+
I'd strip any security from the router and try it as an open box. If you still can't get a connect whilst sat right next to it, take everything else off the LAN, and just try the both of them, double-checking the IP's, go back to basics. Delete all the connections, set a new one with no DNS, no nothing, just try and ping the router.
Without knowing more, don't know what else to suggest really.
Old Jan 6, 2005 | 06:09 AM
Petrucci's Avatar
Petrucci
You don't say much about your settings there, so will be hard to help you. But check DHCP settings on both the router and the adapter. Check the DHCP service is activated on the router, and that the adapter has got "automatically obtain IP address" (or something like this, my Windows has never been in English, so i translate from litteral French ) checked in its properties box.
Also check whether you have WEP enabled or not, because you need to give every adapter the good WEP key (the one that's set on the router) to allow them to connect to it. If you are in a single house and don't fear to share your WiFi with neighbours, you can simple deactivate WEP on the router, will be much simpler if you aren't an expert in networks.
HTH, but can't find your exact prob as you say very few about it
Old Jan 6, 2005 | 06:50 AM
Stu.H's Avatar
Stu.H
as people said, remove all wep security, check mac authentication, just reset to default the router and try from there
Old Jan 6, 2005 | 08:16 AM
Jon ERST S2's Avatar
Jon ERST S2
You haven't got Proset installed have you? God I hate that software!
Old Jan 6, 2005 | 08:53 AM
Petrucci's Avatar
Petrucci
oh yes, check all those shite firewall soft like ZoneAlarm and so are not installed, they are useless and only cause probs
Old Jan 6, 2005 | 08:57 AM
rsdene's Avatar
rsdene
have you got service pack 2 installed?? i had dlink wireless gear and it would work with service pack 2
Old Jan 6, 2005 | 09:14 AM
CraigN's Avatar
CraigN
dont use wep
as said above try it with no encryption
also make sure your standing next to the router for best signal strength
once you are connected enable mac filtering on the router and enter the mac of the wireless adaptor that way no one can access your gubbins and you wont get the wep slow bollox
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
Jul 25, 2004 08:22 PM
AlexF
Jul 7, 2004 09:38 AM
