arp main stud problem
Old Jan 19, 2010 | 09:34 AM
focusrrx87's Avatar
focusrrx87
Default arp main stud problem
any 1 had a problem when fitting there arp main studs? Just started building a zetec turbo and Basically the main studs r about 4mm 2 long and the crank case doesn't sit flush. Have i done it wrong? Any help or advice.
Old Jan 19, 2010 | 11:06 AM
focusrrx87's Avatar
focusrrx87
any one know how to fit arp main studs???
Old Jan 19, 2010 | 11:32 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
There are 2 version s of stud kit for this application what do you have on the box
Matt
Old Jan 19, 2010 | 11:56 AM
focusrrx87's Avatar
focusrrx87
151-5404 is the product code. Trouble i think is needed a new sump and tray coz i found a crack in my donor engine would there be a difference in the sump trays??
Old Jan 19, 2010 | 01:10 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
It is a common problem, you need to clearance the aluminium section of the sump to clear the head of the main studs.
Old Jan 19, 2010 | 01:23 PM
focusrrx87's Avatar
focusrrx87
How do ya go about that? Cut little sections out?
Old Jan 19, 2010 | 01:28 PM
Big Will_'s Avatar
Big Will_
I used a die grinder
Old Jan 19, 2010 | 01:40 PM
focusrrx87's Avatar
focusrrx87
Fair enough it doesn't weaken the tray no?
Old Jan 19, 2010 | 01:44 PM
Big Will_'s Avatar
Big Will_
I very much doubt it, you only need a 5mm x 10mm notch (roughly).
Old Jan 19, 2010 | 01:57 PM
focusrrx87's Avatar
focusrrx87
Would standard bolts wiv locktight be alright 4 a 350bhp engine?
Old Jan 19, 2010 | 02:00 PM
Big Will_'s Avatar
Big Will_
You can use standard bolts at that power level yes. Loctite is a personal preference
Old Jan 19, 2010 | 02:06 PM
focusrrx87's Avatar
focusrrx87
ok thanks m8 im selling those annoying little arp studs! Lol
jessie_rs
62
Aug 6, 2019 09:27 PM
37
Sep 17, 2015 05:05 PM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
hopper350
Sep 4, 2015 12:53 AM
