anyone else having gearbox issues with the cold?
burnzy
as above really i'v been having problems with getting into 1st and 2nd when the box is cold after driving for a few miles it gets better but it's becoming a pain in the arse, so is it just my box or are other people suffering with it too?
mine goes that stiff in my tractor that i carnt ever select the range on the lever but the four gears in each button woek electrically of two buttons there fine good thing is the rear linkage uses the same oil so i just work it and it soon warms up
burnzy
makes me feel a little better that i'm not the only one cheers lads thought it was gearbox change time, it more or less won't go into 1st or 2nd when it's cold i'm as gentle as possible and even double clutch but it's still stiff as frozen shite, just changed the oil and it's actually got worse since but it's also got colder, might try and change it for something a little thinner till the weather picks up.
and rupert i bet my box is as stiff atm it's a joke, and i don't even have the advantage of low range and grippy tyres
burnzy
that and the fact all my door and boot seals are knackered now.
Black Country RSOC
No problems in either my 406 or 306 gti, BUT i jumped into my lasses 2.0 ghia focus today to put some fuel in and that was as stiff as a stiff thing for the first few minutes (same MTX75 gearbox as your Mondeo as well im sure)
Nowt to worry about, its just the bad weather - take it easy and it'll be fine when it warms up.
burnzy
i'm off to london in the morn weather permitting so i'll give it a go in the morn it's not getting it into gear when pulling off though mate it's once i'm moving thats the problem i just hope a syncro isn't on it's way out or summit
Anyone got any ideas my mondy tdci 130bhp had trouble getting 5th
Now its stuck in 2nd gear lever does nothing clutch still works
Do you think it gearbox or selector problem ?
worst morning we had about -38 celsius and the sierras box was pretty sticky
and whiny. After 15 miles of driving worked fine. Local ford dealer said me that if your mondys 2nd gear is sticky use a ATF in box. Neve tried but often heard
