cozzy crank ?
cozzy crank ?
just wondering my crank neads a regrind but it already has been done to .25 oversize. is it possable to regrind again or wil i need a new one .
thanx.
thanx.
You can go to .75 and you can get propper bearings , without useing PINTO items
I used a crank at .75 in an old cossie i had on stage 3 and i propper kicked it everywhere i went , and it is still running perfect today and this is over 5 years ago
I am very interested in peoples opinion as to what is wrong with a crank at .75 so please educate me
everytime you grind a crank you are removing strength from the crank!
is it worth the risk after a rebuild bill?
_________________
_________________
I understand that you are removing strength , but they are a steel crank and will stand .75 without a problem ,,,,
I raced cars for 8 years and reved them to over 8000rpm using a cossie crank at .75 and never had any problems , ok they where not turbo powered but the engineering company say they will go to .75 without any worries and they have built loads of cossie engines for me and i have never had one let go on me yet
plus ,,have you ever seen a snapped cossie crank ????
any problems with cossie cranks are down to two causes
a/ det
b/ oil issues
i know of quite a few descent bhp cars that are on ground cranks with no probs at all.
a/ det
b/ oil issues
Brad
EXACTLY MY POINT
Gareth ,,
People who build engines , repair them etc cover there arses by saying you need a new crank ( imo ) as said i have run many engines that have a crank at .75 and never had any problems ( as said tho this is my opinion ) and if anyone has proof that .75 is a problem then please tell me as i am always willing to learn
I an not trying to start a argument , just interested to know if my opinion is wrong or not
EXACTLY MY POINT
Gareth ,,
Hi...i also use a crank on .50 and would not hesitate to use it at .75 ....never had a problem always had superb oil pressure.
Unfortunatly this is another tuner myth that you must not go over .25 ...i have NEVER heard of a std crank snap in any condition and some drag cars at over 800bhp use std aswell ...plus a new crank is fine for over 600bhp road builds....so a .75 oversize bearing on a stage 3 is hardly getting the stress a 600bhp new crank would be getting!..imo of course
case hardning on jornels cosworth dont even sell a .75 shell the max out at .05
ya take the risk its down to you
i heard horror storys of regrinding bent cranks to .05 on mains cranks gone weak at some point so its bent grinding it stright again is bodging imo
genral rule max mains .5 big end .5 i wuud find another crank personally
now that is a great assumption
brom, no one is suggesting grinding a bent crank straight again. if a crank has some slight scoring that wont polish out a regrind to the next size is no detriment at all.
Brom ,
Nobody said anything about trying to bodge a bent crank
Also if its bent i dont care who you are you wont grind out a bend all we are saying is if its scored etc , and in my opinion and the engineering company i have used for over 10 years there aint a problem .
paul av seen slightyl bent cranks that have been ground to 0.5 to true them up
crank pins out of line due to bearing lockin up and am surwe u know all about what happenswhen they lock up scraps rod and crank or it will grind at .075 but the heat involed with of fuked the crank imo
everybody will do there own thing am not giving out avise am just sayin thats what i wud do if i was building it get another crank imo
DixieTheKid
11
06-06-2020 11:20 AM
timsrs
22
24-09-2015 08:14 PM
