Opinions on GT30 on standard YB?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Head would benefit from being ported to reduce surge. It could be done without but might end up losing the mid range bang as the boost will have to be capped at low revs.
Air injector would be needed for boost control.
For the love of god don't put BD10s in, i've never yet found them to improve a car
rayland can get u the turbo inturnaly gated its around 1200 i think. I have my saff on a standerd engine with bd10 cams groupe a gasket and an exturnal gated gt30 gizzmo boost controler and its got plenty of get up and go would deffo recomend it to eneyone
but why when its not really that hard and have 450ish ponies with 420ish pound foot with the same drivability as a t34. seems a no brainer to me!
been out in cossie richs many a time, the things a weapon and would eat most if not all t34 powered saffs for breakfast!!
The only weak point on a standard cossie is the bore wear and the oil lubrication system, everything else is strong enough to cope, but it depends on how much boost you're going to run and how hard you drive it.
Im interested in peoples opinions on this as Im putting a GTk-450 on a stock yb with autronic managment. Curious to see the result.
http://www.treadstoneperformance.com...s+at+Sema+2006
Is Rich still on the 205 Block then too?? can,t remember tbh..
Mind you, my old Saff ran 456bhp on the 205 block without any problems and 400+ for a good few years before that.
Give it a try Andy i would.....
Personally I'd do it just simply from CossieRich's results alone.
If you were buying new I don't know why anyone would bother with a T34 anymore, great turbo's but totally dated by the roller bearing series turbos.
The ONLY reason I wouldn't use one is on a 205 block but then many have run a T4 on one so no reason why you shouldn't, like anything headwork and other mods really bring the turbo to life as they would a T34 although your talking a lot more power for realistically not a lot more money.
SMILER258
28-09-2015 09:04 AM
