microcat or picture request mt75 gearbox linkage
01-11-2009, 11:30 PM
NOT sorted lol
02-11-2009, 01:14 AM
i have this of the linkages! not sure if its what your after! if you have a pic for me i may be able to be more percise for ya! or if you point it out i will get ya a finnis number
02-11-2009, 02:21 AM
cheers
02-11-2009, 02:36 AM
i will try again bare with me
02-11-2009, 02:41 AM
this more what your after?
02-11-2009, 02:59 AM
Its hard to tell tbh.. i need to get photos of the bush
and the oil leak
The box will have to be dropped again for the linkage and the seal so i will take pictures next time
cheers for the cat pics
02-11-2009, 03:05 AM
ok mate drop me a pm if you need any more screen dumps
02-11-2009, 10:19 AM
Resident Wrestling Legend
the rear seal is v v easy. Prop off undo nut remove stuby 3 inch shaft renew seal
02-11-2009, 10:27 AM
the rubber grit cover does wear nut over time so keep looking out 4 a mint 1
06-11-2009, 12:23 AM
[quote=dojj;4490326]the rear seal is v v easy. Prop off undo nut remove stuby 3 inch shaft renew seal
Cheers for your time...
But i need a name for the pesky rubber OR nylon cap that you carnt see via the pics on top of the selector shaft
06-11-2009, 05:04 AM
Quote:
Originally Posted by
youngben
that'll be number 10 then
and you can't get them
06-11-2009, 07:17 AM
give it a try FINIS# 6188207 priced at around £25
08-11-2009, 02:59 AM
via the noise its item number ten down the tunnel
08-11-2009, 04:42 AM
youngben
nice one but as said it may be a part down the line of the linkage ..
i will get pics when done cheers
08-11-2009, 08:09 AM
Team HOTHOT!
You needing a linkage/cradle - I've still got a full spare one in the garage with lever aswell
14-12-2009, 09:56 AM
i want that number ten thing and graceland how much for yours
TPM961
15-01-2018 10:50 AM
155lee
27-10-2015 04:55 AM
IainRS1700T
25-09-2015 06:44 AM
cossirob
16-09-2015 07:39 PM
gingeRS
04-09-2015 06:29 PM
box ,
drawing ,
focus ,
ford ,
gear ,
gearbox ,
image ,
lever ,
linkage ,
linkages ,
mt75 ,
pics ,
pictures ,
removal ,
sierra ,
technical
