just found out im running over 6 degrees of negative camber
i knew it was out but i didnt realise it was that much.
its at a static 6.15 degrees negative in the garage and increasing as i accelerate and it squats.
what is best for it uncompressed?
i would have thought more like 2 degrees?
sorry yea i mean static cos the car is sat in the garage, and it increases the camber when on road and accelerating.
it is currently 6 degrees negative camber
and a quick search on google brings up that the ideal static camber is 1/2 - 1 degrees?
i wanna set mine up roughly before getting it done properly later on.
stupid google.
i should explain myself more really.
its on my 5, not on a cossie, and its the rear wheels im talkiing about.
its all adjustable so i can do it myself now just wanna get it at the best angle i can before going for a proper setup.
just had a read of simpsons motorsport
they recon 0.5 - 2.5 degrees of static negative camber is ideal so will set mine to 1.5 degrees.
wonder how much difference it will make.
some1 had to say it. lol
im always reading about 6 degree beams on cossies.
without soundin more stupid what exactly are they?
why are they better and what camber do they run not 6 degrees surely?
a 6 degree as i understand it is a beam that allows the camber to change less as it squats or rises.
a 0 degree rear beam would be like a mk1 escort. that just allows the wheels up or down so camber is not affected by squatting
and 18 degree (as standard on cossies!?) allows the wheels to change more - this is why saphs GENERALLY dont do as well 1/4 milees compared to older cars with a 0 degree beam with equal power.
lol ive always known its been out, i just never knew how much by
when it comes to geometry im a bit of a novice, but done a bit of measuring and reading and wolah, still a novice but with a slightly better setup lol
this is only to get me by until i get a pro to do it.
I like the look of that cornering force place you posted about but can't afford it.
I think I will get it done as good as locally then have a play till it feels most comfortable.
I have set it to roughly 1.5 now, I had to wind the top of the wheels out about 20mm each, which means they catch on the plastic arches/ bumpers, so I wound the coilovers up about 25mm each on the rear.
Haven't had chance for a test drive yet.
*** Sierra RS Custard ***
Can you not wind the bottom in a little, rather than doing all the adjustment on the top?
Yes its a shame that the setting up for all the needed data logging equipment with corneringforce is so involved, it does make it very expensive for a "toy" car rather than a serious racer!
Yep too dear for my toy.
The bottom is as far in as poss as it is. It's a shame the frame wasn't made a few mm smaller to get a bit more adjustment.
It's all adjustable but I don't have any room to adjust it lol.
Shafts are fine, helps they are dead level.
And no chip I'd rather not have to cut and weld things, once set they won't need adjustin much anyway, and I'd rather cut a bit of arch away and raise the body a bit for clearance.
Marc sierra
12
30-08-2015 10:38 AM
kosienutter
31
22-08-2015 09:55 AM
track.focus'd
12-08-2015 05:53 PM
