whats the one thing you hate changing on a car?????
Old 14-10-2009, 05:30 PM
  #41
fuzzy
14000+ post superhero
fuzzy's Avatar
the prop centre bearing used to go every couple of months on my bmw. due to the conversion set up a previously simple job now required the removal of the exhaust, driveshafts and diff to slide the prop out the t5. a 1 hour job was now most of the day. 3 times in one year as well.
Old 14-10-2009, 07:02 PM
  #42
TurboShed
Cossiemodo
TurboShed's Avatar
Re-shell on my Sapphire, the ballache started in January and I'm still mopping up bits and bobs.
Old 14-10-2009, 07:06 PM
  #43
.Ross.
.Ross.'s Avatar
Spark arrestor Pot on a Peugeot Partner Van .. Sits under the Exhaust manifold and is held on with two cap heads.
Old 14-10-2009, 07:17 PM
  #44
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
Anything on my car at the moment every time i touch it I find another bodge
Old 14-10-2009, 07:19 PM
  #45
CraigJ
CraigJ's Avatar
MGF/TF as it takes 20 mins just to get to the engine. Best job was removing the engine and box from a 99 passat. the whole front end comes of the car with only about 10 bolts. makes working on the car so much easer.
Old 14-10-2009, 07:32 PM
  #46
foreigneRS
Testing the future
foreigneRS's Avatar
the magic tree - it takes ages to remove the old one from the rear view mirror and slide the packet off the new one and hang it up
if you ever want a tricky job, try changing air con components as most of them are built into the bodyshell before the powertrain is fitted. as an example the air con compressor on a 5.0 jag xkr - workshop book says it's an engine and transmission out job or even worse, change the evaporator as that is a dash out job which is easier on the convertible than the coupe. range rover is not particular nice to work on either.
Old 14-10-2009, 07:40 PM
  #47
89xr2
Brap!
89xr2's Avatar
Did a heater matrix on a 306.. never again. after i put the dash back in the fucker wouldnt run properly again. sold it on for peanuts and apparently the new owner has it running now.
Old 14-10-2009, 08:12 PM
  #48
Received 1,044 Likes on 998 Posts
Any job on a Toyota.Alfa V6s timing belts are a bit of a ball ache.
Old 14-10-2009, 09:05 PM
  #49
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Actually - anything bar the starter motor on a Nissan 300ZX TT
Old 14-10-2009, 09:10 PM
  #50
bamba
bamba's Avatar
headlamp bulb on renault modus....fuckers!
Old 14-10-2009, 09:16 PM
  #51
turboRS
C16OSY
turboRS's Avatar
306 matrix aint too bad considering its a dash out job. try a citreon relay van! you would think being a van its an easy job...WRONG!
the dash comes off in bout a million and one pieces, then its a case of getting the heater box completely out, which sits behind a reinforcement beam
rs turbo boxes are easy on a ramp, just a pain on the floor, on your own!
steer clear of BMW e36 rear wheel bearings
Old 14-10-2009, 09:24 PM
  #52
RST
RST's Avatar
Originally Posted by SiZT
Fiat Coupe 20V cambelt, Clio 172/182 (with A/C) cambelt, first time doing a 1.6 renault cambelt and to a lesser extent C-Max pollen filters
Im doing head, on Fait Coupe turbo at the min. Bit of a fucker.
But the jobs i hate doings are. C.v boots (hate the mess) and Sprinter lower arms.
Old 14-10-2009, 09:29 PM
  #53
ybturbo
ybturbo's Avatar
Oil filter and cleaning the phase sensor (too damn hard to remove the distributor cap due to space) on my cossie 4x4.
Old 14-10-2009, 09:30 PM
  #54
dave cos4x4
dave cos4x4's Avatar
cos 4x4 gearboxes on the drive on your own.
Old 14-10-2009, 10:00 PM
  #55
burnzy
burnzy
burnzy's Avatar
mine has to be the mondeo clutch on my own and the plate isn't a very good one and seems to get hot quickly so going to have to uprate it sometime soon
Old 14-10-2009, 10:08 PM
  #56
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
the floorpan on my mk 3 project
not exactly a in and out job lol
beef
Old 14-10-2009, 10:16 PM
  #57
benjaminsarmy
escort rst cosworth rep
benjaminsarmy's Avatar
the engine in my escort as you allready know mate
Old 14-10-2009, 10:25 PM
  #58
jammy86
jammy86's Avatar
Anything on a KaRST. Especially if its coolant or boost hose related. Look at the engine and your hand hurts!
JAmes.
Old 15-10-2009, 09:10 AM
  #59
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
lol so funny how many different people like some jobs but hate others but for the next person its the otherway round
Old 15-10-2009, 10:15 AM
  #60
SiZT
SiZT's Avatar
Did you pull the engine out or use the old grinder trick?
Old 15-10-2009, 10:34 AM
  #61
Markb_s1
Markb_s1's Avatar
anything that involves a cambelt due to paranoia of getting it wrong and reaking expensive stuff... and the clutch on a v6 cavalier. that sucks!
Old 15-10-2009, 12:36 PM
  #62
Fezza
H71 CNX
Fezza's Avatar
Brake discs on a 206. Fuckin star-screw seizes and has to be drilled out. PITA
Old 15-10-2009, 01:27 PM
  #63
Rs1
Rs1's Avatar
Shock them with a.......resonable size hammer, or impact driver come out no probs then.
Rear brakes pipe on a 2cv, i hate them.
Old 15-10-2009, 02:47 PM
  #64
bluescortcossie
bluescortcossie's Avatar
got to be a power steering pump or coilpack on a mk1 ka with aircon , no room for owt
Old 15-10-2009, 02:50 PM
  #65
godrikki
godrikki's Avatar
anyone tried taking the front bumper off a mk2 mr2 50 bolts that are a pain in the dick to get to
Old 15-10-2009, 03:11 PM
  #66
The Youth.
The Youth.'s Avatar
without doubt the worst ever is the alternator on a 24v v6 mondeo, took me 8 hours and had to remove a driveshaft for access! you need 4 long extension bars to reach the top bolt!
would rather set fire to the car than do that again
Mind you a close second is putting a 2.0 pinto in to a 100E that only took 9 years lol
steve
Old 15-10-2009, 03:27 PM
  #67
clarke5700
clarke5700's Avatar
or as you are changing the disks any way wack the back of them with a club hammer it stretches the head of the screw and makes them very lose
Old 15-10-2009, 04:29 PM
  #68
craigybaby
craigybaby's Avatar
rear main oil seal not hard just a bloody pain gearbox clutch and flywheel have to come off to replace a seal that costs about 1.50 but you'd pay big dow in a garage
Old 15-10-2009, 05:06 PM
  #69
dojj
Resident Wrestling Legend
dojj's Avatar
washer pump on a mk3 mondeo
even topping the air con up means removing the off side front inner wheel arch liner to get to the top up nozzle
and fuel pumps on the mk3 is a suspension out job
Old 15-10-2009, 05:09 PM
  #70
carcollector
carcollector's Avatar
changing the radiator on a classic mini
Old 15-10-2009, 05:38 PM
  #71
fiestamad
fiestamad's Avatar
pistons on eny car with no piston kit just some screwdrivers and brut muscle lol
Old 15-10-2009, 07:14 PM
  #72
tosh
tosh's Avatar
The time and date on the clock in the cossie because it usually wrong because the battery has gone flat through lack of use
Old 15-10-2009, 09:59 PM
  #73
RST
RST's Avatar
Engine is still in there. Cut one of my torx`s 40 bits right down to undo the timing belt covers, with the Engine mount off to allow the Engine to move up and down. Should be putting it back together tomz. Great! lol.
Old 15-10-2009, 10:23 PM
  #74
Bloomers
Cornish Fasty
Bloomers's Avatar
Clutch on a st185 Celica GT4 proper pain in the ass
Old 15-10-2009, 10:35 PM
  #75
deanocossie
deanocossie's Avatar
anything on a shitreon c8 no room at all to work on it pain in the ass
Old 31-10-2009, 12:18 AM
  #76
scoby_hugh
scoby_hugh's Avatar
Starter motor on a 205 gti sounds so simple but its a pain cos theres no bastard room
Old 31-10-2009, 01:00 AM
  #77
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Originally Posted by Mondeo Man
HCV on a mk5 fiesta/puma etc, skin my fuckin knuckles every time!
managed to slice my finger open when i did mine bloody thing!
JoeyBoyden
04-01-2024 02:36 PM
tankybaby66
09-08-2015 07:13 AM
Kevin_Mc
06-08-2015 07:47 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: whats the one thing you hate changing on a car?????
