Technical question help needed by 10am
Old Aug 31, 2009 | 07:18 AM
fordpop's Avatar
fordpop
Default Technical question help needed by 10am
Hello all, I know its the wrong section but need opinions and comments by 10am so posted here
Would a set of bike carbs from a 1000cc motorbike that spins at 12000rpm be capable of supplying enough air to a 2000cc car engine at 6000rpm?
Obviously the jets can be changed to allow the fuel flow but would the air flow be restricted by the size of the carb chokes?
This is for a non turbo application, just N\A
Thanks
Old Aug 31, 2009 | 07:26 AM
mark_24v_wiring's Avatar
mark_24v_wiring
basic answer is yes it should work
Old Aug 31, 2009 | 07:29 AM
fordpop's Avatar
fordpop
Thats what I thought but need some more persuading before I part with the dosh hahaha
Old Aug 31, 2009 | 07:32 AM
mark_24v_wiring
That would depend on the amount of cash you gotta part with really then you gotta make a manifold up etc might do as well to find a set of webbers or similar
Old Aug 31, 2009 | 07:34 AM
Icurus's Avatar
Icurus
I have a set of throttle bodies from a Suzuki GSXR750 on my 2.0L and it makes @ 7000rpm 180bhp.
I take it you mean throttle bodies and not carbs? as the carbs may not have the correct jets available to supply enough fuel?
Old Aug 31, 2009 | 07:35 AM
fordpop's Avatar
fordpop
They come on a manifold already, not sure if they will work without the bike airbox as some need negative air pressure to work. we tried running open carbs on a GSXR and needed to change to Flatslide Keihns due to that reason
Old Aug 31, 2009 | 07:37 AM
fordpop's Avatar
fordpop
No Carbs, I can't afford throttle bodies as this is a second project after the racing Sapphire Cos
Old Aug 31, 2009 | 07:46 AM
Icurus's Avatar
Icurus
Mind you thinking about it, and its a bit early in the morning for my brain!, your halving the revs but doubling up the cc each carb supplies, so it may work!
Old Aug 31, 2009 | 07:55 AM
fordpop's Avatar
fordpop
That was my logic
If it uses "X" amount of air for a 1000cc motor at 12000rpm
Surely halving the revs but doubling the cc """should""" be about the same volume of airflow.
If these carbs are good for 170-180BHP on a bike they should be able to cope with 160 ish on a car
Old Aug 31, 2009 | 08:22 AM
fordpop's Avatar
fordpop
up for any more comments
Old Aug 31, 2009 | 08:28 AM
pee vee's Avatar
pee vee
yeah they will do the job to an extent.
most '45' webbers ETC used on cars have chokes in them down to about 36 or 38mm anyway to keep the air speed i think.
Old Aug 31, 2009 | 08:31 AM
fordpop's Avatar
fordpop
Plus you can't turbo Webers but you can Dellortos and bike carbs
Old Aug 31, 2009 | 08:36 AM
CraigJ's Avatar
CraigJ
Yes they will work. most people use smaller carbs from zx6 etc so carbs of a 1000cc bike will be ok. you best of speaking to bogg bros, http://www.boggbros.co.uk/ this is what they do for a living.
Old Aug 31, 2009 | 09:14 AM
fordpop's Avatar
fordpop
Magic craig many thanks
Chas
Sep 21, 2015 08:57 PM
borboyous
Aug 22, 2015 11:17 AM
dal3door
Aug 13, 2015 06:55 AM
Ben26
Aug 11, 2015 04:19 PM
col93saphcos
Aug 7, 2015 03:21 PM
