Puma Ka project
Old Aug 10, 2015 | 02:35 PM
Ben26's Avatar
Ben26
Default Puma Ka project
yea yea I know it's a common topic. But I can't seem to find what I need on this
Oh and hi again. I've been away for a year havin a baby. So I thought I would start of with a cheap project
Ok picked up a analogue dashed v reg 1.7 puma. £285 happy days
Couple quick question now:
1: can I put the whole puma dash into the ka
2: which gearbox shall I use. , the ka or puma one. Pro,s and con,s
3: with the whole dash comin out anyway is it easier to change the whole loom over ?
4: anything else I mite need to know to make this easier for me
Cheers. Ben
Old Aug 10, 2015 | 06:57 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
1. Yes with a small bit of cut and shut. Basic width and depth is close enough, same heater unit etc.
2. Both can be used. A lot of people for simplicity keep the KA box and shafts etc for simplicity as it solves g/box mount issue. However, puma set up is better with equal length shafts etc. However it wont bolt up dead easily. You need a custom engine mount anyway so knocking up a custom gearbox and torque link isnt really a big deal. Also you may need to cut and shut the wishbones or cut and shut a puma subframe to fit as the track is slightly different and ideally you want it all from one model to make it easier to fix and to keep geometry and ability to bolt together spares the same.
Had i continued with my ka project I was planning on fitting a puma subframe to the ka with some relatively simple shell and subframe tweeks.
3. Changing the whole loom is fairly easy like that although you will need to think about how you will fit the battery junction box in engine bay plus a few connectors need swapping over.
Old Aug 10, 2015 | 11:38 PM
Ben26's Avatar
Ben26
Ok cool mate nice info. It's nice that there are still people out there that will take a bit of time out to help people still. Happy days
So if I do use the ka box will the starter be a problem ?
Also what's your opinion on using the puma PAS ?
Old Aug 11, 2015 | 04:19 PM
Psycho Warren
Carbon Crazy
Most the KA's ive seen the starter is on the front of box so cant see an issue. Certainly wont be an issue if you use puma box etc.
Puma PAS works fine. You can use the PAS pump with KA rack or puma rack. If you use puma subframe you may want to use the puma rack anyway as it bolts to the subframe where as on the KA it bolts to the bulkhead instead.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gambo08
Feb 4, 2016 10:49 PM
SMILER258
Sep 28, 2015 09:04 AM
youngben
Sep 27, 2015 09:37 PM
