General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
excellent glad to hear you got it off,what are doing with the input shaft? are you going to run a brass bush as a spigot bearing.
the skyline input is 16mm in diameter,the ford spigot bearing is 15mm,so to run a standard ford bearing you would need to strip the entire gearset to get the shaft ground down.i think the brass bush is easier but they dont last as long.
definitely a worthwile conversion this, my old r32 was pushing near 600 hp on a tired old box and that never gave up even doing back to back low 3 sec 0 - 60 runs.
mk motorsport is sorting mine out so it should be done in a few weeks i hope
is mark doing the measuring and welding as need to get mine done still looking at what clutch to use was thinking of using the gtr clutch plate and cosworth cover
