left hand drill bits
Old May 25, 2009 | 12:16 PM
tracktoy's Avatar
tracktoy
Default left hand drill bits
serious question- i know they exist as i had some years ago but cant find any for sale now
any body know who sells left handed/ anti clockwise drillbits??
Old May 25, 2009 | 12:19 PM
jon@work's Avatar
jon@work
Snap-On do them
blacky.'s Avatar
blacky.
last set i seen was in with a set of stud extractors
Old May 25, 2009 | 12:48 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
what would you use them for? probably a stupid question . . .
Old May 25, 2009 | 01:01 PM
COLEYST200's Avatar
COLEYST200
iv just been on EBAY and put in left hand drill and they came up
Old May 25, 2009 | 01:34 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
what would u use a left hand drill bit for that you couldt use a standard one to do ?
serious question ,
beef
Old May 25, 2009 | 01:35 PM
Spiky's Avatar
Spiky
extract a stud or something
Old May 25, 2009 | 02:01 PM
-beefy-'s Avatar
-beefy-
spiky i always had it pegged that you would just use a small standard drill bit , then use a left handed tap or extractor ?
not an actuall drill bit
beef
Old May 25, 2009 | 03:16 PM
nicksaph's Avatar
nicksaph
beef
use a left hand drill bit for drilling the hole in a broken stud and somtimes the stud will come out while it is being drilled.
cheeRS nick
Old May 25, 2009 | 04:47 PM
Fast Guy's Avatar
Fast Guy
Surely if it will come out when being drilled it can't be that tight because as soon as the drill bit gets a hold of anything it should cut off whatever it's biting into? Therefore a normal drill bit with a stud extractor should be fine?
Old May 25, 2009 | 05:42 PM
Stu.H's Avatar
Stu.H
Anyone seen the square drill bits for square holes?
Yes they do exist
Old May 25, 2009 | 06:05 PM
J98 FYA's Avatar
J98 FYA
square drill bits the 1s for morticin wood not metal???
Old May 25, 2009 | 06:50 PM
AJ_ERST's Avatar
AJ_ERST
anybody want some left handed screw drivers, or some tarten paint
Old May 25, 2009 | 06:58 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Yes they do exist
mortice cutters? square cutters with a drill bit inside giving a nice square hole.
Old May 25, 2009 | 10:43 PM
tracktoy's Avatar
tracktoy
Originally Posted by jon@work
Snap-On do them
cheers guys , i tried ebay earlier but found nothing, got a page full now
bang on the money
beef
trouble with stud extractors is that it puts pressure on the wall of the broken stud making the problem worse and nine times out of ten it will snap in the hole or just not grip
i know what your saying but it has worked a for me in the past, must be something to do with the heat and vibration
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
dal3door
Aug 13, 2015 06:55 AM
Perfmr2
Aug 6, 2015 07:30 AM
