boost problem?
Old Apr 4, 2009 | 04:29 PM
kieran265's Avatar
kieran265
Default boost problem?
i have a fiesta rs turbo 1991 and have noticed that its not as fast as it used to be, i put it down to the clutch slipping. i now know that thats not the case and its only boosting at 4 psi were as before it was boosting it 10 psi. can i adjust the boost myself or is that for a profesional? also wot would cause this to happen i have checked the 2 pipes cumin from boost controler and these seem fine.
any help/advice would be very appreciated.
thanks kieran
Old Apr 4, 2009 | 07:27 PM
martysmartie's Avatar
martysmartie
thanks kieran
I would suggest a faulty boost controller with ignition on see if you can hear the boost controller clicking if it is this means it's faulty, alternativly unplug it and then go for a drive and see if its still the same this would also indicate its faulty. I don't see adjusting the boost is going to help TBH as it must have dropped for a reason if it has not been adjusted.
Certainly you just can not adjust the boost safely without professional equipment.
Martin.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
