another running issue
Old Mar 3, 2009 | 09:29 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default another running issue
is it wrong for me to want to break my saff and buy an m5
Jim Galbally's Avatar
Jim Galbally
no
Old Mar 3, 2009 | 09:30 PM
carlo's Avatar
carlo
i cant talk i have a similar urge
Stu @ Claims Care Centre's Avatar
Compensation Specialist
i love my mates m5 brillaint to drive
JTECH James
Passion for Fords!
god its just problem after problem
Old Mar 3, 2009 | 09:31 PM
BigErn's Avatar
BigErn
Dibs on the T4
RONNIE AMIS's Avatar
RONNIE AMIS
i often think about it too, wont do it though
The DIVA's Avatar
The DIVA
You`ll be bored shitless, don`t do it
Old Mar 3, 2009 | 09:32 PM
JTECH James
Passion for Fords!
the worst bit is, im sure it would break for enough to go and buy an m5
i was thinking about the E46 M3 i just want a car i can drive to work everyday and then go on the tracks and know ill be getting home ok
Old Mar 3, 2009 | 09:33 PM
carlo's Avatar
carlo
whats up with it now mate?
Old Mar 3, 2009 | 09:34 PM
JTECH James
Passion for Fords!
i dont know, driving the saff is hard work now, all ive acheived it seems is making an expensive car i dont like driving because it hurts
im hurting all over
Old Mar 3, 2009 | 09:35 PM
Paul_RS's Avatar
Paul_RS
If its breaking in a month or so - dibbs on the bara box
Old Mar 3, 2009 | 09:36 PM
JTECH James
Passion for Fords!
over fuelling on cylinder 2, badly...
it may be the injector got damaged when the valve seat broke up...
but im getting fed up
RONNIE AMIS
did you intend for it to be an everyday car or just weekends and tracks?
Old Mar 3, 2009 | 09:38 PM
JTECH James
Passion for Fords!
i dont really know
Miller 3's Avatar
Miller 3
Originally Posted by Jim Galbally
yes
i will never have that urge
Originally Posted by Stu @ Claims Care Centre
i hate my mates m5 boring to drive
Old Mar 3, 2009 | 09:40 PM
Dicko&Vacant's Avatar
Dicko&Vacant
james ill swap you a nice seat leon lol
Old Mar 3, 2009 | 09:44 PM
JTECH James
Passion for Fords!
well one thing is for certain, if that fookin engine has to come apart again...it aint going back together
it runs sweet, goes like hell, cruises at 15:1 afr, but as soon as i over run down a hill, it goes onto 3 cylinders, no 2 spark plug will be soaked in fuel, when i get to the bottom, i have to swap plugs then its fine again...
Old Mar 3, 2009 | 09:49 PM
JTECH James
Passion for Fords!
i cruised home today, and dipped the clutch on every hill, to avoid over run situations, removed the plugs at home and.....
Old Mar 3, 2009 | 09:50 PM
JTECH James
Passion for Fords!
im gonna swap injectors tomorrow and see if the fault moves cylinders
Old Mar 3, 2009 | 09:51 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Swap the injector on number 2 to another cylinder and see if it follows - if so, ring tomorrow and we'll try and sort a solution for you
The DIVA's Avatar
The DIVA
Good idea fella, hopefully it will be a cheap fix
Old Mar 3, 2009 | 09:52 PM
Big Will_'s Avatar
Big Will_
Doh - great minds!
Old Mar 3, 2009 | 09:53 PM
JTECH James
Passion for Fords!
i just have visions of it being something horrible
compressions are dead even hot and cold, loom is new, ecu was tested not long ago,
i dont know what else it can be really,
i dont get why it runs fine, then does this on over run, i suppose the injector could be firing consantly, during the normall running it masks the fault and burns the fuel off, but it causes agro on over run
Old Mar 3, 2009 | 09:56 PM
Miller 3's Avatar
Miller 3
As said got to be something silly' like a leaking injector? You have swapped the plugs over already haven't you Jay
Old Mar 3, 2009 | 09:57 PM
JTECH James
Passion for Fords!
thanks will
Old Mar 3, 2009 | 09:58 PM
JTECH James
Passion for Fords!
spark plugs are being changed at the bottom of every hill
Old Mar 3, 2009 | 10:18 PM
thebigyin's Avatar
thebigyin
yep that man is correct, the power , refinement, quality,comfort, reliability, looks style, image, etc etc etc are REALLY boring the arse off me
what a stupid thing to say
Old Mar 3, 2009 | 10:31 PM
Stu @ M Developments's Avatar
PassionFords Creator
Pull the fuel reg pipe off the penum and suck hard, see if you can suck fuel through it.
Old Mar 3, 2009 | 10:34 PM
JTECH James
Passion for Fords!
its an aeromotive reg stu, does the same apply to them? i picks it vaccum up from a remote unit which runs off the rear of the swedish plenum
Old Mar 4, 2009 | 02:55 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have just changed all 4 of my plugs as they all look like your Number 2 plug
Mine is so rich on start up it missfires. Even after getting the car to Temp and going for a good drive the still look like that
Steve.
Old Mar 4, 2009 | 08:33 AM
Ian M500COS's Avatar
Ian M500COS
Steve.
I had this problem many years back and it turned out to be my plug leads!!
Old Mar 4, 2009 | 08:39 AM
carlo's Avatar
carlo
Dont say that ian he has just bought fancy leads
Old Mar 4, 2009 | 10:14 AM
Cossy Mike's Avatar
Cossy Mike
Don't say the word break Jtech, your saff is the nutts!! looks really well from what Ive read it goes like stink!,
I want your wheels!!!!!
Did you roll the arches or put them straight on?
Old Mar 4, 2009 | 11:36 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Well its not my new leads as this morning was the first time i had even started the car after fitting them.
Car run a bit better on my old plugs, but im still not happy
Steve.
Old Mar 4, 2009 | 05:50 PM
JTECH James
Passion for Fords!
breaking
Old Mar 4, 2009 | 05:54 PM
Miller 3's Avatar
Miller 3
Arrr come on James it cant be that bad' at least get it mapped before you make any rash decisions' you know you will regret it otherwise
Old Mar 4, 2009 | 05:55 PM
Jim Galbally
welcome to BMW land mate
Old Mar 4, 2009 | 05:59 PM
JTECH James
Passion for Fords!
its not injector, its not plug lead, i reckon its something with the bore, maybe i honed it to much to remove the damage from the valve seat,
ive had enough tbh, ive lost interest after what happened last time
