turbo timer help .
Old Feb 17, 2009 | 02:34 PM
sortedsaff's Avatar
sortedsaff
Default turbo timer help .
ive been going through the wiring in my sapph today and found a turbo timer tucked under the dash seems its half connected .
could someone tell me what it actually connects to to work?
im left with 3 wires that need connecting a red ,yellow and blue
Any help would be much appreciated
Old Feb 17, 2009 | 02:36 PM
steveturbocal's Avatar
steveturbocal
depends what make it is
Old Feb 17, 2009 | 02:39 PM
sortedsaff's Avatar
sortedsaff
i cant find a make anywhere on it nor on the black box the wiring runs to
its this one
Old Feb 17, 2009 | 02:48 PM
Look around the ignition switch and the relays behind glovebox, may get a clue from something there ?
Old Feb 17, 2009 | 03:01 PM
RSTurboSI's Avatar
RSTurboSI
red goes to red, yellow goes to yellow and blue goes to black, should also be conected to your hand brake so when the car is on turbo timmer and the hand brake is removed it will cut out.
sortedsaff's Avatar
sortedsaff
thansk for the reply guys . think i might have to have another look and some more head scratching .
all the wiring is around the back of the clocks . the wires that are connected are an earth and 1 wire spliced into one of the wires on the back of the clocks(maybe for illumination??) then there is 3 loose wires on the right hand side behinde the clocks.
Obviously they will need to connect to something as at the mo its only earthed and illuminated . what do they have to be connect to to work?
These are the 3 loose wires
Old Feb 17, 2009 | 05:34 PM
sortedsaff's Avatar
sortedsaff
bump . anyone any ideas?
matt maybe?
Old Feb 17, 2009 | 06:08 PM
snoopaloopa's Avatar
snoopaloopa
As RSTurboSI said mate, they are basically fooling your ignition so you need to connect them around the ignition cowling area, in a like for like styley
Old Feb 17, 2009 | 06:17 PM
Jim Galbally's Avatar
Jim Galbally
Turbo Timer: For NA and Turbo Cars
erm, WTF?!
Old Feb 17, 2009 | 06:21 PM
SteveH's Avatar
SteveH
Jim beat me to it
Old Feb 17, 2009 | 06:28 PM
dojj's Avatar
dojj
Resident Wrestling Legend
that looks like the same one i've got screwed into the seirra
if you can wait till tomorrow afternoon i can see what's wired in where (it's tucked up in the drivers side glove box so all the wires go through the dash and into the ignition loom)
but i'm pretty sure that two of them will connect to the coresponding wires in the ignition switch, one for keeping the power running when oyu switch it off and one to the earth side
there should also be one that kills the power if youdrop the handbrake, it's a sort of anti-robbery thing if you leave the car running and wander off and osmeone else jumps in to run away with it
Old Feb 17, 2009 | 07:01 PM
sortedsaff's Avatar
sortedsaff
dojj mate that would be fandabbydosy
thanks all for replying ill have a look tomorrow
Old Feb 17, 2009 | 07:04 PM
dojj's Avatar
dojj
i might just ventrue out this evening if the mrs can be distracted
Old Feb 17, 2009 | 07:49 PM
dojj's Avatar
dojj
right then
i've got a red wire
and a black wire
and a green wire
red goes to red
black goes to the one with the blue trace
and the green goes to the yellow
Old Feb 17, 2009 | 08:07 PM
sortedsaff's Avatar
sortedsaff
hmmmmmmm seems you got less wires than me dojj .
ill have a look at it again tomorrow .
Thanks for taking the time out to look for me . much appreciated
Old Feb 18, 2009 | 11:37 AM
sortedsaff's Avatar
sortedsaff
right then ive been out for a look this morning and i have the following
black-(connected to earth)
brown-(connected to back of clocks)
blue-not connected
red-not connected
yellow-not connected
think i might pull it out and start again maybe try find a wiring diagram for it
Old Feb 18, 2009 | 12:00 PM
dojj's Avatar
dojj
there is a stripey one for the handbrake and there were 3 other wires that went into the ecu of the jap versions to count injector pulses or soemthing to automaticaly work out how long to run the timer for
the instructions i had were all in foriegn so i binned them
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
