what good value for money pressure regs are there for cossie?
24-01-2009, 08:26 PM
500bhp Cosworth in making
next on my list is a uprated pressure reg what options have i got and good value for money?
24-01-2009, 08:28 PM
i thought standard was the best?unless you going to aerogrip the fuel pipes?
24-01-2009, 08:31 PM
so std pressure reg is ok for 500+bhp?
24-01-2009, 08:33 PM
Pass fella!can not say for certain just always thought that standard where good enough!Sure someone will be able too say for certain!
24-01-2009, 08:38 PM
PassionFords Creator
Quote:
Originally Posted by
Roosie
Yes, its fine.
24-01-2009, 08:46 PM
What do u think of the Sard units stu? For a none YB, would it be worth considering seeing as you don't already have a weber unit as std?
25-01-2009, 10:14 AM
The pressure reg isn't the problem, so lonmg as it has suffecient flow for 500bhp from the pump it will regulate to whatever it is set to.
25-01-2009, 10:22 AM
Colossal Pervert
That is incorrect. If your fuel pump is big enough you can have issues if the regulator can't bypass the excess.
25-01-2009, 10:25 AM
Passion for Fords!
or if it doesnt raise rate correctly, nomatter what its "set" to, it will still be lincorrect on full boost.
I'll have to think about that one, but you would have to be seriously over pumped to do that.
25-01-2009, 10:26 AM
It won't be incorrect on full boost in Roosie's case as he is having it mapped with the reg on that he is using, hopefully on 9th feb.
25-01-2009, 10:30 AM
Passion for Fords!
but, you increase fuel presure 1:1, so you still have the correct pressure on boost.
u would have to be a fool to map it at less, with an inconsistant reg.
25-01-2009, 10:31 AM
Colossal Pervert
The issue is you can't get the fuel pressure LOW enough if you're over-driving the regulator. Try it and see.
25-01-2009, 05:25 PM
i agree,, i could be like trying to drain a bath through a straw LOL
25-01-2009, 08:43 PM
Rick
i run one of these has rising rate etc etc blah blah lol and works superbly..
only piece of jap junk ive ever owned and works fine
25-01-2009, 09:38 PM
stage 3 muppet
Works superbly,what a piece of junk
What a life you must lead not having any jap junk around the house
regards mark
25-01-2009, 10:36 PM
Mark_w
regards mark
think you missed the point mate
never owned jap car before and will be the only part that is jap on my car and works great
and yes i have mucho jap stuff around my home like the laptop im using right now ..doesnt mean im gonna use it as a fpr though does it lol
original
30-01-2022 08:20 PM
markk
02-12-2021 06:59 PM
lukeeboy149
22-08-2015 04:29 PM
Red_bull
09-08-2015 08:34 AM
Caddyshack
15
04-08-2015 08:50 AM
