CVH inlet manifold on Zetec head...
As above, just wanted to know how the CVH inlet manifold fits the Zetec head??! Is is a straight fit?! does it require a spacer/adaptor plate made?!
also are there any benifits from using the CVH inlet??! personally think the CVH inlet looks alot better...
cheers for any help
rich
cheers for any help
rich
Spanner monkey
rich, you need an adaptpr plateto the head and a spacer plate between the 2hgalves of the inlet as the zetec head is taller!!
Ian had some a while back but sold em
Think i'll get on the case and make them cant be that hard to make
did ian get them made at work?!
Spanner monkey
no mate, bought them from Ian howell but they looked like they'd been carved out with a spoon!
i have an inlet you can chop up to make the bits!! it's on my tool box. come and see me tomorow, i'm starting at 1.15!
Originally Posted by B19-TRB
One soff Ian Howell r absolute shite!
Speak to Philm c if he can knock u a set up!
best bet if u r gunna make em is go get a cvh inlet gasket & a zetec gasket draw round both on the same peice of card & it should be self explanitory from there!
& the spacer plate to raise the manifold up to go over the Zetec engine is piece of piss as it just needs to be the same both side! Ian howell managed to fuckeven that bit up!
you should've asked me to make you a set mate-would've been a lot cheaper too
gonna try and get the gaskets shortly, might have a CVH one in hte garage cheers for the advice tho i'll post up some pictures when i've done em...
have you got any pictures of yours?!
PassionBMW.com Member
I dont make them plates sorry m8! Easy enough to do, 1hr on CAD and get it laser cut. However the CVH ports and the Zetec ports are very different and it cant be good for airflow.....as you can see:
CVH Gasket
Rover Manifold - Much nicer port shape
CVH Gasket
do you know if the bottom part of the rover manifold can be made to fit the CVH top part?! how do i get round the different ports sizes if i did use a CVH inlet
cheers for the pictures did you get my pm yesterday about the pistons...
Nott sure about the PM, ill look now m8!
The CVH and Rover plenum cant be mated no!!!
Most people just use the CVH one anyway and dont think about the airflow, seems to work, but isnt right imo!
Replied Why not just use a ig ally Escort 1800 inlet, similar style to the Fiesta one realy, but with matching ports
you got pm
https://passionford.com/forum/viewtopic.php?t=35995
well helpful that guide, hope to do something similar when i start building mine
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
Si B
12-09-2015 06:49 AM
