pics of the vm engine got it running today :)
got the 3.6 vm td engine running today after 5 days of messing about with it but to be fair has been stood for 10 years. gonna try put it in the e30 in te pics
engine is free and its not hp its torque, i have been in a range rover with this engine in on an auto box and the grunt was far far superior to a e36 325 tds engine. sounds awesome to
engine is now out. im gonna fit bmw flywheel where torque converter was fitted so basically running 2 flywheels ! the flywheel and clutch is half the weight of the torque so should pick up quicker than it did in the rangie. flywheels and adaptor are being machined just gota then fit them, fit gearbox and drill new holes for mounting. oil pan needs moving forward about 6 inches to clear crossmember and i think engine will then fit few pics from wednesday
had the engine in for a dummy run with gearbox just bolted on roughly and got gearbox within an inch of original gearbox mounts but couldnt drop the front right down as sump fouls on the crossmember.
just done speed calculator with gear ratios, 4200 rpm rev limit and a e36 325 tds 2.56 crownwheel and pinion and it came out at 1st 30 mph, 2nd 56 mph, 3rd 85 mph, 4th 113 mph and 5th 142 mph. im thinking that looks pretty good to use the low down grunt.
picked flywheels and adapter up today, bit of fettling and new mount holes drilled in bmw flywheel and its on perfect. within 1mm of original clutch position on the original bmw engine.
JoeyBoyden
04-01-2024 03:36 PM
kosienutter
31
22-08-2015 10:55 AM
Zoggon
10-08-2015 11:39 AM
yawiejon
15
09-08-2015 07:36 PM
