Cosworth traction control
Old 18-09-2008, 01:53 PM
Kaliber Cosworth
Kaliber Cosworth's Avatar
Default Cosworth traction control
This is what is in my car does anybody recognise what make it is?Was it similar to the actual touring cars as it was kaliber fitted apparently,you have a dial on the dash to dial in how much you want it to work?Any info appreciated.
Old 18-09-2008, 02:27 PM
Kaliber Cosworth
now the dyno thread has gone maybe other users topics might get a look in
Old 18-09-2008, 02:29 PM
Maria.
Maria.'s Avatar
good luck!
Old 18-09-2008, 02:35 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
what would you like to know pm would probably be best in light of the recent problems on pf
infact it would probably be far quicker for me if you rang me 01782 564222
Old 18-09-2008, 02:37 PM
Kaliber Cosworth
pm sent to mike rainbird first so you can then correct him tony
Old 18-09-2008, 02:43 PM
Maria.
Maria.'s Avatar
people are still entitled to their own opinions on here tony, and id hate for peole not to discuss things openly on here, its only when it gets silly and repetitive that i feel its uneccessary.
Old 18-09-2008, 02:44 PM
Kaliber Cosworth
maria i also thinks its best he replies on here
Old 18-09-2008, 02:45 PM
Turbosystems
Super Moderator
Maria in light of mr rainbirds current mood I feel it best that I don't post any technical answers,if only my ignore button would work
Old 18-09-2008, 02:49 PM
dunketh
Chief Iron Oxide Farmer.
dunketh's Avatar
Whats with all the cloak and dagger stuff?
I dont own the car myself but I'd be interested in how it works.
I cant imagine how they've added adjustable traction control to something thats totally mechanical and reasonably low tech.
There must be some other electronics/servors/stepper motors/etc.. involced somewhere...??
Turbosystems
Super Moderator
The problem as I see it is that Mike gets the last say as he can post when a thread is locked
perhaps mike would be so kind as to answer this technical query and i promise not to correct it
Old 18-09-2008, 02:50 PM
Turbosystems
Super Moderator
no there isn't
Old 18-09-2008, 02:53 PM
dunketh
dunketh's Avatar
no there isn't
Old 18-09-2008, 02:55 PM
Turbosystems
Super Moderator
I have offered to explain by phone but kaliber thinks I dislike him but I have no idea who he is.
It would be far quicker for me to explain by phone
Old 18-09-2008, 02:56 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by Tony S Mannock
no there isn't
Oh !! yes there is.
sorry Tony could not resist it.
Tony tell us how this works cos I for one would like to know, remember only you & I were born when this was high Tec.
Old 18-09-2008, 03:04 PM
GUZZLER
GUZZLER's Avatar
i reckon you just want to talk 'dirty' to him
just post it here
Old 18-09-2008, 03:06 PM
Kaliber Cosworth
can we just drop the mike rainbird thing? Tony you seem to be not wanting to reply as a protest against mike which is naff all to do with any of us.With all the replies you have done on this thread you could have breifly explained how it works!
Old 18-09-2008, 03:09 PM
philram
Mulechild
philram's Avatar
if i remember rightly its a racelogic system.. probably wrong though
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Tony,
dont divorce yourself from reality mate. If Mike has a problem leave him to it.
This thread seems interesting, so your technical input is required like 10 posts ago
Old 18-09-2008, 03:10 PM
XRT_si
XRT_si's Avatar
Id be interested to know how this works too!
Maria.
Maria.'s Avatar
Tony just spit it out... and no i dont mean your dummy.
Old 18-09-2008, 03:13 PM
Turbosystems
Super Moderator
I agree with the above
maria I have no dummy to spit out mike has it
Old 18-09-2008, 03:14 PM
Nash
Cake lover!
Nash's Avatar
Does it work off the brakes Tony? Using sensors to detect when the wheels slipping?
Old 18-09-2008, 03:19 PM
Kaliber Cosworth
The next stage is to get the electronics fitted. The system comprises of a small wiring loom, a controller box, a dashboard control and the optional spark control box. These were mounted under the dashboard and in the driver's footwell. The dashboard control was mounted in the central console where I could at get it when strapped into the car. The control allows the degree of control to be adjusted and also has the all important launch control button. The system also has a data logging facility and a serial connection is provided to plug into the onboard data logging PC. This gives detailed analysis of what is happening to the wheels and the car when driven. It can even detect when wheels lift off the ground!
The variable control is an important feature. Many standard traction control systems err on the safety side and will prevent any wheel slippage at all. This can prevent experienced drivers from driving the car in the way they want. At one sprint, on frustrated competitor was seen with a mobile phone in one hand talking to Ford about ways that the traction control could be disabled on a Puma. Every time he started to push the car, it kicked in and slowed him down. The variable control allows the driver to select the amount of intervention that is required. It can even be switched off. In practice, this could almost be described as a tail slide control. The less intervention, the more the tail would slide and the more correction the driver would need to provide.
Old 18-09-2008, 03:20 PM
Turbosystems
Super Moderator
it monitors the wheel speeds and uses the non driven wheels as it's reference depending on this difference it will limit the engines output by varying amounts upto a it's most severe point of total engine cut.The amount of desired wheel spin can be adjusted by the pot on the dash,you do not want no wheel spin
Old 18-09-2008, 03:21 PM
Kaliber Cosworth
i assume it works off abs and spark is that a correct summary i copy passted tony?
and was it the same system used in touring race cars?
Old 18-09-2008, 03:23 PM
Turbosystems
Super Moderator
first you need to tell me who you are as apparently i don't like you
traction control was never fitted to the rs500 touring car it was not allowed in the regs
yours will have been fitted by a later owner as a retro fit
Old 18-09-2008, 03:25 PM
Physio
Physio's Avatar
I very much doubt it's your ex wife Tony
Old 18-09-2008, 03:26 PM
Kaliber Cosworth
Tony the car was used by the public who won competitions to have a go on the track (with a race driver) and get a touring car feel but with half the power and they fitted traction to help keep the car straight.
Turbosystems
Super Moderator
I love my x wife i just couldn't eat a whole one
Old 18-09-2008, 03:27 PM
Turbosystems
Super Moderator
they fitted traction because these numpties couldn't drive roflol
Old 18-09-2008, 03:29 PM
Kaliber Cosworth
got an entry form to drive my car back in the late 80's with andy rouse,i must check the expiry date
Old 18-09-2008, 03:30 PM
Turbosystems
Super Moderator
It's not that I dislike you kaliber it's more the fact that nobody likes you
Old 18-09-2008, 03:33 PM
dunketh
dunketh's Avatar
So it monitors the speed of the wheels then cuts engine power when one slips a lot?
So it cant 'move power' from say one wheel to another, like modern stability systems can?
How does it monitor wheel speed? Is it some kind of dodgy belt system like the ABS on RSTs?
Sounds very interesting. I know traction control was fitted to later granadas/scorpios. I wonder if you could hack about that later system to fit a cos... (shooting the breeze here as I dont own either...)
Old 18-09-2008, 04:04 PM
phil_rs
yam yammer
phil_rs's Avatar
Agreed
Only joking Steve
How's ze german tank now? Still broken?
Old 18-09-2008, 04:16 PM
Kaliber Cosworth
hi i am not kaliber cossie
Thanks for the info all,i will be trying it out tommorrow,be interested how it compares to modern day rwd TC.
JK12
33
26-04-2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
Marc sierra
12
30-08-2015 10:38 AM
14-08-2015 07:29 AM
Quick Reply: Cosworth traction control
