why would a cossi run backwards
Old Sep 7, 2008 | 01:10 PM
bamcossi's Avatar
bamcossi
Default why would a cossi run backwards
when trying to start it keeps running backward for some reason all timing is correct im a bit puzzled
Old Sep 7, 2008 | 01:11 PM
LHD220Turbo's Avatar
LHD220Turbo
WTF; what you on about?
Old Sep 7, 2008 | 01:12 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
running backwards? rolling backwards ?
Old Sep 7, 2008 | 01:13 PM
KnoxyGtt's Avatar
KnoxyGtt
T34 just kicked in Yo
i think he means the engine is turning the wrong way
Old Sep 7, 2008 | 01:14 PM
J1mbo's Avatar
J1mbo
B1mbo
is it when cranking or when it trys to fire it runs opposite ?
Old Sep 7, 2008 | 01:18 PM
louie1's Avatar
louie1
Talking
Timing sounds like its out mate.
Do you mean it tries to fire then backfires and turns backwards then stops.
(maybe you have fitted a lhd starter lol)
Old Sep 7, 2008 | 01:19 PM
bamcossi's Avatar
bamcossi
when the engine is turning over its trying to fire and then the engine stops and tries to run backwards i have checked the timing and its all correct i have put a new map sensor on and tried a different ecu as well but this does not help any ideas cheers
Old Sep 7, 2008 | 01:24 PM
louie1's Avatar
louie1
did you time the bottom end up on the lug of the pulley tdc 1 and not the groove next to it??
Old Sep 7, 2008 | 01:27 PM
bamcossi's Avatar
bamcossi
yes noticed that and check its ok thanks
Old Sep 7, 2008 | 01:29 PM
louie1's Avatar
louie1
only other main thing is that you have the dizzy in the right place pointing at the indent in the metal housing of the dizzy.
Old Sep 7, 2008 | 01:31 PM
bamcossi's Avatar
bamcossi
yep done that one also keep em coming lol much aprieciate it
Old Sep 7, 2008 | 01:33 PM
SteveH's Avatar
SteveH
If the timing is ok and the dizzy is ok how can it run backwards?
the spark must be before TDC for it to fire backwards, somethings definately wrong
Old Sep 7, 2008 | 01:34 PM
bamcossi's Avatar
bamcossi
tell me about it im going back to check again
Old Sep 7, 2008 | 01:35 PM
SteveH's Avatar
SteveH
If the timings out you're lucky to not be bending valves
Old Sep 7, 2008 | 01:36 PM
louie1's Avatar
louie1
have you removed the leads for any reason? what have you done before this went wrong.
Red16's Avatar
Red16
Old Sep 7, 2008 | 01:37 PM
louie1's Avatar
louie1
are the leads on the dizzy cap in reverse order maybe
Old Sep 7, 2008 | 01:39 PM
louie1's Avatar
louie1
make sure the rotor arm is fixed on the shaft and not broken the little lug off
Old Sep 7, 2008 | 01:43 PM
Csm's Avatar
Csm
Has the bottom pully still got the little lugs intact and not broken off that the sensor picks up ??
Dunno just a thought as they dont run without the lugs
Old Sep 7, 2008 | 02:42 PM
stage 3 muppet's Avatar
stage 3 muppet
mine does it occasionally mate when its stopped just doesnt have the inertia to get past compression stroke,
so it just turns the opposite way until its off cam lobe
no probs only does it once in a while ...and yes timing spot on etc ..always thought it weird myself but just put it down to being a twin cam
Old Sep 7, 2008 | 02:48 PM
bamcossi's Avatar
bamcossi
ive built this saf from a shell engine come from ebay ive just been back in garage took all leads off marked em all up and refitted to book specs .
rechecked timing its timed up correctly with the lug just before the v the rotar arm lines up with mark on dizzy all spot on it just wont run
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
muz
Aug 1, 2015 06:48 AM
