will a hybrid t2 make a lot of diffence on a fiesta?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I'm sure you've been told over & over again not to put a T2 on your fiesta as they are prone to problems......or am I wrong are there are 2 people called paceo on PF with a Fiesta Turbo with turbo issues that post at least 5 times a week with similar questions!!??
no its becuase i had that rebuild done by you know who and i have the results of the internals on that rebuild from tony. apart from that i have had no issues with a t2.
as for 5 times a week id like to know where you got that from!
Stick a T3 on the T2 is expensive and not up to delivering anything.
the t2 can deliver alot the main issues are with it's installation which is a ford design fault on the fest turd these can be redressed
there are no advatages to fitting a hybrid t2 on a standard car at standard boost.mod the oil return and mod the breather
What housing did you have it on. I ran my FRST on a T3 with .36 and it went like stink. Little lag and delivered the goods. Knocked the crap out of the T2 I removed
i had a T2 hybrid type of thing a few years ago built up from a T25 (small turbo esc cossie), it used the exhaust housing from the escort cos and the core, with a Sunny GTiR comp housing and comp wheel (60trim)
was an awsome turbo regards to lag and response, but at 2bar boost just eat thrust bearings about every 20minutes !!
its beyond me why people still fuck about with T2's on fiesta, unless there bog standard show cars then why bother?
as for those who say there car is quicker on a T2 i sugest you get your car set up properly!
It cost fuck all to put a t3 on a fiesta anyway, only reason it got one is becuase the t2 was shagged and came across a t3 for 70 bangers, cant remeber what u needed again since it was 2 yeara ago but think it was the escort turbo braided oil feed line, the little oil return bung that goes into the block and 2 90degree bends for the turbo to the cooler, i just used some old hose that was the same'ish shape for the oil return and just used any crap hoses to join up for the water feed and return, all in all it cost like under 130 or something
