P0133 fault code
Old Sep 4, 2008 | 04:44 PM
RichieST's Avatar
RichieST
Default P0133 fault code
Hi all, this fault code has popped up in my ecu. I know it is a lambda sensor, but which one? Pre or post cat? Have had a search around on the www, and it seems to be coming up with conflicting answers!
Thanks all
Rich
Old Sep 5, 2008 | 07:50 AM
RichieST's Avatar
RichieST
Bump for the day shift
Old Sep 5, 2008 | 08:26 AM
Jay246's Avatar
Jay246
O2 Sensor CKT Slow Response (Bank 1 Sensor 1)
This is what my DTC Code Library Software came back to me with
Old Sep 5, 2008 | 08:28 AM
RichieST's Avatar
RichieST
cheers for that jay, so would sensor 1 presumeably be the first pre cat sensor?
Old Sep 5, 2008 | 12:11 PM
iansoutham's Avatar
iansoutham
OCD Victim
Bank 1, sensor 1 is post cat.
Bank 1, sensor 0 is pre-cat on most cars.
Old Sep 5, 2008 | 01:20 PM
mechanic28's Avatar
mechanic28
i know on vx sensor 1 is pre and sensor 2 is after not that this prob helps!
Old Sep 5, 2008 | 01:38 PM
RichieST's Avatar
RichieST
Ok thanks for that, have got hold of a list of dtc codes, turns out there is a sensor 1, sensor 2 and sensor 3!!
Can't be 3 lambda sensors can there?
Rich
Old Sep 5, 2008 | 01:48 PM
mechanic28's Avatar
mechanic28
i have never heard of sensor 3 personally u can have 4 sensors fitted i.e for a v6 etc but usually it will be broken down as sensor 1 bank 1 or sensor 2 bank 1 then sensor 1 bank 2 and sensor 2 bank 2 bank 1 would be for example cylinders 1,3,5 and bank 2 for 2,3and 6
Old Sep 5, 2008 | 01:50 PM
RichieST's Avatar
RichieST
yeah that makes sense! I'll just take an educated guess and change the pre cat one
Old Sep 5, 2008 | 03:36 PM
pani_k's Avatar
pani_k
PassionFORD Member
I had that one mate and found it to be the green one lol. I think one is with blue cabling and one green and it was the green one that was fucked but can't remember where it was. Have a look and see which one it is. P0133 was the fault code on mine too.
I cant remember right now but I have a slight feeling it's post cat as the blue one I remember being pre cat although I'll check in a little while to make sure.
Old Sep 5, 2008 | 06:36 PM
RichieST's Avatar
RichieST
Ok mate thanks for that, i'll have a look too when it stops chucking it down!!
Old Sep 5, 2008 | 06:49 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
if you have a code reader clear the code and unplug them in turn to figure out which one it is your after.
I got myself one of them cheapo ebay code readers, it's saved me a fortune
Dan
Old Sep 5, 2008 | 08:27 PM
RichieST's Avatar
RichieST
Dan
Thats a good idea, what code reader is it you have?
Old Sep 5, 2008 | 08:34 PM
SillyFezzaMk1
Rubber Rhino Crew
Just a cheapo ebay jobbie.
search for ODB2 code readers.
Think I paid £20 delivered for mine......thats less than 1/2 what a garage charge for 1 diagnosis session.
Dan
Old Sep 6, 2008 | 09:10 AM
RichieST's Avatar
RichieST
ok cool thanks dan, will look into it!
Rich
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
