Ignition Computers/Controllers?
Old Nov 8, 2004 | 01:34 PM
Rick's Avatar
Rick
Default Ignition Computers/Controllers?
Does anyone know what's available? I'm after something that can adjust the base ignition map to suit a new engine spec on a non mappable car
Old Nov 8, 2004 | 01:37 PM
Jim Galbally's Avatar
Jim Galbally
microdynamics make some products to do this. EMS 5/5/6 etc.
dont know much about em tho.
i assume MSD (not stu's MSD, the other one) make similar products
Old Nov 8, 2004 | 01:44 PM
Rick's Avatar
Rick
any links?
Old Nov 8, 2004 | 01:47 PM
Jim Galbally
www.google.co.uk
Old Nov 8, 2004 | 01:53 PM
Rick's Avatar
Rick
Old Nov 8, 2004 | 01:58 PM
MWF's Avatar
MWF
Have you looked at the MegaJolt system?
Old Nov 8, 2004 | 02:04 PM
Rick's Avatar
Rick
No I haven't - i have no idea what's available - any info much appreciated
Old Nov 8, 2004 | 02:12 PM
MWF's Avatar
MWF
I aren't too genned up on the Megajolt and MegaSquirt systems, all I know is that they are mappable systems you can build up really cheaply and people all over the net are now using them, here is a link to some Megasquirt info
www.bgsoflex/megasquirt.html
But I aren't sure if MegaSquirt can just be used for ignition, it's designed to do it all.
Old Nov 8, 2004 | 02:13 PM
MWF's Avatar
MWF
Megajolt
http://picasso.org/mjlj/index.jsp
Old Nov 8, 2004 | 02:16 PM
MWF's Avatar
MWF
These guys make a piggy back ignition controller, don't know of anyone who has used it tho
http://www.perfectpower.com
Old Nov 8, 2004 | 02:51 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if you just want to adjust the base setting all over the range, i.e. retard it 6 degrees all over or whatever, i would say that the megajolt/squirt is too involved. maybe easier to just buy an MSD one as jim says.
but why would you want to do that, and can it not be done by turning the dizzy/phase sensor?
Old Nov 8, 2004 | 04:39 PM
Rick's Avatar
Rick
Yes i could adjust the dizzy, but thats not what i want to acheive. I want to be able to alter the timing at different points in the rev range. Trouble is there is no crank position sensor, and some of these things seem to need one. All i need is something that maybe can interupt the coil ground and retard/advance it.
Old Nov 8, 2004 | 04:58 PM
MWF's Avatar
MWF
I'm pretty sure the MSD stuff can do it, they even make some mappable electronic dizzies which replace some standard items.
Old Nov 8, 2004 | 05:34 PM
NUTS RuS's Avatar
NUTS RuS
Lumenition C400 Rick ?
Can use the hall effect of the dizzy as a controller I think
Old Nov 8, 2004 | 05:58 PM
Rick's Avatar
Rick
will have a look
Old Nov 8, 2004 | 06:08 PM
Rick's Avatar
Rick
Seems to be a full computer? Prob too much for what i need. Apexi do something along the right lines, but not sure if it will work without crank sensors.
Old Nov 8, 2004 | 06:15 PM
DazC's Avatar
DazC
I THINK I have sorted mine out....
Secret Squirrel!!
Old Nov 8, 2004 | 06:19 PM
NUTS RuS's Avatar
NUTS RuS
C400 is ignition only (dizzy)
C410 tooth operated trigger
C451 Fuel and ignition via dizzy
C460 Fuel and ignition via toothed trigger
Thats what Alan at DTA came back with
Old Nov 8, 2004 | 06:28 PM
Rick's Avatar
Rick
Daz - PM me :P
Tony - any more info - nothing online - how much is it etc. Cheers
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
