problem with cossie engine!!!
Old Jul 31, 2008 | 04:47 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default problem with cossie engine!!!
cossie engine was chucking water out of number 2 cylinder. and had 2 bent valves.sent head away to have valves done and presure tested.bolted it all back 2gether and its still chucking water out.trying to get hold of bloke who did it to make sure he pressure tested it!! find out tomorow. another mate of mine reckons it could be bottom end.any1 else any ideas or had same problem???
going to take head off in few days to have a look.
Old Jul 31, 2008 | 04:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I would just scrap that car the amount of crap its given you
Steve.
Turbosystems's Avatar
Turbosystems
Super Moderator
pressure testing is a waste of time
Old Jul 31, 2008 | 05:03 PM
rickbartlett
G911 TTA
Steve.
i know steve.had to buy a new ecu aswell,now its all gotta come apart again.well pissd off mate
rickbartlett
G911 TTA
y is pressure testing a waste of time mate?
Old Jul 31, 2008 | 05:27 PM
rickbartlett
G911 TTA
im so close to just givin up with it but i always sed once i was 25 i wud get 1.now ive got 1 but nothing but trouble
Old Jul 31, 2008 | 05:31 PM
LHD220Turbo's Avatar
LHD220Turbo
stick with it mate; trust me it'll be worth it
Old Jul 31, 2008 | 05:35 PM
rickbartlett
G911 TTA
cheers mate,just so annoying built it all up was well happy till this happened.a mate of mine reckons a liner could have moved or sumat
Old Jul 31, 2008 | 05:52 PM
LHD220Turbo
we all have trouble with em; part of cossie ownership! - whip the head off and see whats occuring.
Old Jul 31, 2008 | 08:22 PM
rickbartlett
G911 TTA
yeah gonna take head off 2morow.just need a change of luck with it!!
Old Jul 31, 2008 | 10:09 PM
mechanic28's Avatar
mechanic28
cracked liner?
Old Jul 31, 2008 | 10:12 PM
nuttynil's Avatar
nuttynil
RS nutta
if the heads ok it gotta be a block problem cracked block possibly....keep with it
Old Jul 31, 2008 | 10:17 PM
Rs sid's Avatar
Rs sid
I just love fords!
I said that mate i wont a cossie before i buy a house iam 24 and have spant nearly Ł8000 on mine just getting it on the road but now every new it drives so nice and i dont have any trobble with it, just got 2 buy some nice wheels fore it as it been running around on some Ł100 shiters!!!
Old Jul 31, 2008 | 10:18 PM
Rs sid's Avatar
Rs sid
I just love fords!
Originally Posted by mechanic28
cracked liner?
I have seen a 2wd one craked a liner and had bent valves when we took the head off at work.
Old Jul 31, 2008 | 10:36 PM
magentasafchris's Avatar
magentasafchris
This is so spot on i have nothing but trouble with mine, endless night's in the unit covered in shite and then endless day's arguin with the mr's next day.
You can't beat and nothing can replace that big fat smile on yer face though when you're thrown back in you're seat and all hell break's loose under the bonnet.
It's like a drug addiction only more expensive
Old Aug 1, 2008 | 06:33 AM
rickbartlett
G911 TTA
thanks 4 all comments.im hoping its the head cos i think that will be cheaper 2 replace.c wot happens wen get head off
Old Aug 1, 2008 | 08:48 AM
scoooby slayer's Avatar
scoooby slayer
in my experience head pressure testing can show a problem but some cracks will only leak when the head is hot and the crack expands.
the original's Avatar
the original
please tell us why, struggling with something similar on mine at the moment. cheers
Old Aug 1, 2008 | 08:52 AM
Turbosystems
Super Moderator
basic answer is as above
pressure testing will only show an obvious problem which you could see with your own eyes
Old Aug 1, 2008 | 11:15 AM
rickbartlett
G911 TTA
ive pressure tested the cooling system and its blowing strait out of number 2 cylinder with the plug out .engine hasnt been run at all
Old Aug 1, 2008 | 11:25 AM
rickbartlett
G911 TTA
just bin told cossie 205 blocks dont have liners so i take it they cant be f##ked then?
Old Aug 1, 2008 | 11:28 AM
coswurv's Avatar
coswurv
you can have liners fitted to a 205 block yes
Old Aug 6, 2008 | 04:18 PM
scoooby slayer
if the head has been pressure tested and doesnt leak then it wont leak with you cold must be headgasket or more likely cracked cylinder bore leting water in.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
